Partner Tepee 2012 American Park
08.05.2020 18:16 # 1
mertcemokur
Hi; Can anyone share or have experienced this subject?
08.05.2020 18:16 # 2
rizeli_53
If you search the forum on this topic, you can get information.
08.05.2020 18:16 # 3
mertcemokur
Thanks Smile
08.05.2020 18:16 # 4
barishrocker
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-aksesuar-tuning-otomobil-arazi-araci-amerikan-park-sinyal-modulu...elektronik-ve-parlaklik-ayarli- 139748646 / detail /
The friend said it was good for the polo .. But I did not see it ..
08.05.2020 18:17 # 5
Bunyamin.Kar
If you have a little electrical experience, its installation is simple. There is already a brochure explaining the installation in detail in the package.
08.05.2020 18:17 # 6
mertcemokur
I need to post a thread here because everyone said something different for the circuit, thank you :)
08.05.2020 18:17 # 7
Alicilik
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/amerikan-sinyal-park-modulu-kargo-bedava-101647041
Take it, the assembly is done with a little electrical knowledge.
08.05.2020 18:17 # 8
mertcemokur
There is a module enabled but how should I find the Plus-Minus poles? both cables are black Unhappy
08.05.2020 18:17 # 9
yawruaslan
[QUOTE = mertcemokur] Module exists, but how should I find the Plus-Minus poles? both cables are black Unhappy [/ QUOTE]
frankly, I was wondering right now: D
08.05.2020 18:17 # 10
mertcemokur
I found the plus and minus poles, I put everything on, but when the parks open, the signal and the parks flash twice at the same time :(
08.05.2020 18:17 # 11
yawruaslan
[QUOTE = mertcemokur] I found the plus minus poles, put everything on, but when the parks open, the signal and the parks flash twice at the same time: ([/ QUOTE]
What do you think ?
08.05.2020 18:17 # 12
mertcemokur
With the help of LED
08.05.2020 18:17 # 13
volkanC2
Did you reverse it?
08.05.2020 18:17 # 14
Alicilik
There's probably a link.
Things to do,
Finding the plus of the signal
Find the plus of parks.
If I am not mistaken the blue one of the cable, you connect it to the plus of the park. You cut the plus of the signal. You connect one side to the black bulb side and red to the side. Look at the scheme it still works this way.
08.05.2020 18:17 # 15
mertcemokur
I am sure that I connected correctly, electricity comes, when the circuit is reversed, none of them are already lit: /
08.05.2020 18:17 # 16
Alicilik
It seems to me that the cables are connected upside down. Because both of them are burning together, it thinks that the cable going to the signal goes to the park.
