Partner Tepe allure when I take my foot off the gas
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
15.03.2021 23:42 # 1
Mamisus
I wish good evening partner tepe allure 2012 when my vehicle is on the road, the gear does not matter when I take my foot off the throttle, the vehicle throws itself forward when I go slowly, it is the same even when I go slow, it is more obviously the same, the same light brake is as if I took the engine mounts in good condition, nobody could find the problem I took the trouble to the service, opium blessed brothers They could not find it, they said it could be an injector. There is no problem in the traction of the car, no smoke throwing. Mamisus 2021-03-15 23:44:47
18.03.2021 17:54 # 2
It may be related to the flywheel, sir. I would also say clean the air flow meter in addition. finally when did the Mozat filter change? and recently fueled at different stations.
18.03.2021 18:11 # 3
Mamisus
I buy from Opet, the filter timing maintenance has been newly done 1 month ago, EUROREPAR brand had this fault before maintenance.
19.03.2021 11:49 # 4
basr
Similar problem with my 1.4 Hdi Euro 5 vehicle and it has been going on for a long time. It also knocks when it comes to grip in gear shifts. In moments when I quickly pull my feet from the gas, it is in the form of instant shaking. Frankly, I did not go on much, but if the pressure lining changes, I will also enter the flywheel. One of the possibilities in my mind is a clutch switch. I guess a bit old on my transmission mount. I will change it in the coming months. I will let you know if my problem is solved but my guess is one of them.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
