Partner stops and doesn't work when the brake is pressed
14.12.2020 15:35 # 1
Emrepeugeot3535
Hello everyone, I could not find my problem anywhere, finally I felt the need to write to the forum. My Vehicle 2006 1.9 Diesel Partner. Spark plug, injectors have been cleaned and the circuits have just changed. My car stops as soon as I touch the brake while I am cruising, and when I try to start it again, it seems to be running slightly and it shuts off. Pouring water no longer works either. Is the exact solution to pump repair or could it be from other things? Emrepeugeot35352020-12-14 15:39:35
14.12.2020 15:53 # 2
pevgeot307XT
Have you changed the diesel filter?
14.12.2020 16:19 # 3
Emrepeugeot3535
[QUOTE = pevgeot307XT] Did you ever change the diesel filter?
14.12.2020 16:26 # 4
pevgeot307XT
Is there a problem in the first run, idle etc.
14.12.2020 21:50 # 5
Emrepeugeot3535
[QUOTE = pevgeot307XT] Is there any trouble in the first run, idle etc. [/ QUOTE] Speed rises and falls
15.12.2020 09:22 # 6
Actually, you found the problem yourself, sir. The fuel pump is probably not creating enough pressure. I think get it checked out. I say and ask for warranty if it is repaired.
