Partner Steering Wheel Removal
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:06 # 1
06OzGuR06
Friends peugeot partner 2007 Do you have any information about how to disassemble the steering wheel? I have tried several times but I could not remove the airbag in the steering hub.
08.05.2020 17:06 # 2
Alicilik
The other day I changed the steering wheel of my own car with the skin.
There is a hole below the lower arm of the full steering wheel. There is a thick wire in the hole when you push that wire, the belly comes out. You remove the chassis of the horn and gently remove the airbagin socket behind the bottom bracket.
In order not to encounter any problems and get errors, disassemble the battery terminal. Reviews
08.05.2020 17:06 # 3
06OzGuR06
[QUOTE = Buyer] I changed the steering wheel of my own car the other day.
There is a hole under the lower arm of the full steering wheel. There is a thick wire in the hole when you push that wire, the belly comes out. You remove the chassis of the horn and gently remove the airbagin socket behind the bottom bracket.
Disassemble the battery terminal to avoid any problems and errors.
Yes, I do this operation. Of course, I removed the battery terminal and there are 3 holes on the back of the steering wheel. I push the wires inwards. It just comes out. For some reason, it does not come out.
08.05.2020 17:06 # 4
Alicilik
The system may be different. Maybe the wires do not fully release.
