Partner Original Tape Removal
08.05.2020 14:02 # 1
Emre Firat
Hi friends, I hope I will have a question about the original sound system change. they disassembled and cut the sockets when the tape changed. Then they soldered their old cables again and put the original tape back on the car. I wonder if there is such a possibility. How should I connect the mp3 player? I am 16 years old.
I think I opened the issue to the wrong place now, I am opening it here again, I hope it will not be a problem.
08.05.2020 14:02 # 2
hasimayaz
There is no such thing. You can disassemble and install a new one, but you should use a tape with universal socket under one condition. Do not cut the original sockets on the vehicle.
08.05.2020 14:02 # 3
Emre Firat
I think the tape should have a socket on it, but I don't know the warning. If I did something like that, let's say the socket did not fit the car. There were two sockets on your tape, I would appreciate it
08.05.2020 14:02 # 4
hasimayaz
what is the unit in the vehicle ?? RB3 or RD3 ?? or can you put your picture? ..
08.05.2020 14:02 # 5
Emre Firat
I don't have the opportunity to put pictures because my uncles reside in Izmit. There are two columns on the doors, the original cassette player, I will have one more question without forgetting the tape. Brother, the vehicle enters eco mode in 30 minutes. This creates a problem. Does this happen in this tape as eco mod?
08.05.2020 14:02 # 6
hasimayaz
ECO mode is canceled. Only if your new tape has battery backup support will it turn itself off when the contact is closed. If you press the power button again, it turns on. When it comes to the cable event, whichever standard your tape recorder uses, the universal converters are always available on the market. Always use macaron for wiring instead of electrical tape. There is no such thing as the vehicle not working, I know tens of rb3 units in the market, I heard the first time. Unit RB3 in your vehicle, I add the scheme for help
08.05.2020 14:02 # 7
Emre Firat
Thank you very much, brother, the template helped a lot, but I have one more question. There are 2 sockets.
08.05.2020 14:02 # 8
hasimayaz
[QUOTE = Emre Fırat] Thank you very much brother template helped a lot but one last question will be 2 sockets from which one I will get from which A is B:):):) [/ QUOTE]
look at your nails .. one in the middle and the other on the edge ..
08.05.2020 14:02 # 9
Emre Firat
Sorry, I'm sorry, I did not pay attention
