partner idle speed
08.05.2020 14:55 # 1
kasirga85
friends partner 2005 What should be the idle speed for the 1.9 D vehicle, our vehicle's idle indicator is 11-12 above 10, is this normal? I think it should be lower
08.05.2020 14:55 # 2
Faruk
When the engine starts first, it is above 10 when the engine is cold, then it drops to 2 below 10 when the engine warms up.
08.05.2020 14:55 # 3
elnino35
Well, I don't know a partner, but it is a normal problem in my vehicle, but if you want, show it to be related to throttle settings.
08.05.2020 14:55 # 4
kasirga85
The same idle speed is above when the engine is hot or cold, so is the noise of the engine running? kasirga85 2010-10-18 18:24:10
08.05.2020 14:55 # 5
dogu
my brother-in-law got the 2.0 2.0 hdi, when it was cold but 10 and 2 when it was hot
08.05.2020 14:55 # 6
Faruk
[QUOTE = kasirga85] The same idle speed is above when the engine is hot and cold, is it because of the loud operation of the engine? [/ QUOTE]
make the setting solved ..
08.05.2020 14:55 # 7
oguzhan29
i had berlingo 1.9d my kide was over 10 normal brother
