Partner hill 2.0 hdi warning light help
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 19:58 # 1
Volkan31
Friends like a hat on the far right, and like a Sea wave below
It turns out I took the picture but I can't add it to the site
Does anyone know why? Volkan31 2016-09-15 21:11:11
08.05.2020 19:58 # 2
reality59
When was the first thing that came to my mind, when did you last replace the diesel filter diesel filter?
08.05.2020 19:58 # 3
Volkan31
2-3 months already in terms of maintenance
Then there was a problem because the car was first started to post
He was doing it once a day, the stop was flashing and
That warning on the right is a bit of action
After cutting, it is hardly cut during the day.
It did not repeat today, 2-3 times repeated video you Tuna
Let me throw it and share it, meanwhile, the fuel consumption is 1.5 times in the vehicle.
It has increased somewhat and sometimes I have trouble with traction
For example, when I threw from 2 to 3 and loaded on the gas, the vehicle was flying, now it is like saying if you don't go or some
08.05.2020 19:58 # 4
Bha41
If the lamp in the picture is the coolant level teacher.
08.05.2020 19:58 # 5
Volkan31
I add the YouTube link
https://youtu.be/clhemx1mhcg
08.05.2020 19:58 # 6
Volkan31
Yes, he is very happy :) he has been trying to find this symbol since morning
08.05.2020 19:58 # 7
Volkan31
Why does this coolant warning light? What should I do to get it back to normal?
08.05.2020 19:58 # 8
reality59
Check the radiator water, if there is no shortage in the water, your level tray will be broken and it will cost 40-50₺.
08.05.2020 19:58 # 9
Volkan31
[QUOTE = reality59] Check the radiator water if there is no shortage in water, your temperature level tray is broken.
Thank you very much, hojam, the heat has always been more than 90 clicks. Where we add water to the car, the water is completely visible, I did not look into the radiator
08.05.2020 19:58 # 10
Volkan31
I wrote wrong, I can't delete this message Volkan31 2016-09-15 21:44:36
08.05.2020 19:58 # 11
reality59
In this weather, the temperature over 90 is very normal especially in urban use
08.05.2020 19:58 # 12
Volkan31
[QUOTE = Bha41] If the lamp in the picture is the coolant level teacher.
Yes, teacher, this was the warning. I think we found the problem.
08.05.2020 19:58 # 13
Volkan31
[QUOTE = reality59] Over 90 degrees of heat in these weather is very normal, especially in urban use [/ QUOTE]
Hodja, you got me
I'll go halfway and have a custom.
My lonely car changed its oil and filters 2-3 months ago. On the traction I can say 9 over 10 and 7 now. When I go to industry tomorrow,
If you are in Izmir, we can meet with you
08.05.2020 19:58 # 14
Volkan31
I closed the car to the biker 15 minutes I did the shopping, I turned the switch, I said that they did not have 2 lines of diesel.
08.05.2020 19:58 # 15
error
The wrong level information comes from @volkan buoy as each vehicle gets older.
08.05.2020 19:58 # 16
reality59
For low traction, the air filter may not be seated properly, the flow meter may be contaminated.
If diesel oil decreases while the vehicle is stationary, there may be a leak somewhere. If you are sure that there are no leaks, it may be due to flow meter or air filter. It should be connected to the diagbox in more detail.
Thank you for your invitation, but uncle Tekirdag :)
08.05.2020 19:58 # 17
Volkan31
[QUOTE = errör] @volkan the wrong level information comes from the buoy every time it gets older. [/ QUOTE]
Tmm, teacher, I will take it tomorrow.
08.05.2020 19:58 # 18
Volkan31
[QUOTE = reality59] Air filter may not be seated properly for low traction, flow meter may be contaminated.
Thank you for your invitation, but uncle Tekirdag:) [/ QUOTE]
Sagol my master, finding such information, illuminating the question marks in our minds gave me a lot of peace today.
I always wait for you if you have a way around here :) I love my car and I am happy to discover problems and find solutions.
08.05.2020 19:58 # 19
reality59
Fb.com/omur.onder.capkin
Beautiful as you share life 😌
08.05.2020 19:58 # 20
Volkan31
good morning friends
The vehicle is now connected to the machine, my father called
Fuel consumption and reduced traction
Electronics from something between the engine and exhaust
It may be necessary to look at the brain
My father couldn't say his full name only between 300-509 pounds
A piece of sound that needs to be done
Find and call the mechanic's number,
I will understand. But it can't be done here
İzmir Gaziemir 6. Industry recommended a special Bi service
What do you think could be?
Page : / 2
