Partner High Speed Drop Speed
08.05.2020 17:19 # 1
salemsmithh
First of all, good forms everyone.
2006 model 2.0 hdi partner. I used the 2006 model 2 times before. (From those with 7,000 cycle hours). These tools are for example 2. The speed is between 60-70 kms at 4,000 rpm. 5. The gear speeds up to 140 km in 3,000 cycles (5th gear 4,000 rpm 170 km) 2. The gear is 20 km at 2,000 rpm, 30 km at 3,000 rpm, 5th gear is 95 km at 3,000 rpm, 110 km at 3500 rpm. The Buddha causes it to drink officially. Could the engine be deaf or the clutch is missing ? Waiting for your help :)
08.05.2020 17:19 # 2
Ectorq
Hello, I have the same problem in my 2006 Partner 1.9D. The traction is not like the 2.0 hdi but it goes around 80-90 at 3000 revs in 5th gear. When I take my foot off the gas, the car is holding itself even though I am on the straight road. I went to the master, he is holding the linings tight, he does not have the problem. He does not hold the linings, which causes the car to burn a lot, I cannot overcome the fear over 3000 cycles. When I go over 3000 cycles, it can burn more than 50 kr per km :(
08.05.2020 17:19 # 3
Mami86
This problem shows that the direct printing pad is dead.
08.05.2020 17:19 # 4
salemsmithh
But when I pull it out of the clutch without stepping on the gas, the car rushes. My father and the elders around me are not from the lining, he said. this problem bothers me
08.05.2020 17:19 # 5
cerci07
Gearboxes are different
08.05.2020 17:20 # 6
salemsmithh
how can the gearbox be different :) we used it before the same
08.05.2020 17:20 # 7
cerci07
the speed and speed ratio generally change due to the differences in transmission and wheel sizes. The same is not the same & nbsp;
08.05.2020 17:20 # 8
salemsmithh
So do you think there is a mistake in the car
08.05.2020 17:20 # 9
cocomo
there is a problem with turbo
08.05.2020 17:20 # 10
PsychosociaL
Greetings Everyone & nbsp; 2001 Partner I think the engine is deaf Working at idle in 40th gear at 40 km Is there a way to correct this Engine deafness aceba in advance Thanks ..
