partner door motors burned ... repair attempt ...
08.05.2020 19:09 # 1
arslanalp
Greetings ... I just joined you ... Give me my 2003 model 1.4 gasoline / lpg partner vehicle. I am very happy with the vehicle. and I think it was worth our own sight. the doors started to open or not. There was a triggering sound like a snap, but there was no movement in the motors. I removed the left middle door last week. I saw that electricity was coming to the motor but there was no movement in the motor. Meanwhile, the fuses were intact. ........... s placed the engine in such a way that it was riveted to the door and I just had to shear to remove the engine .... http://i.hizliresim.com/lkP91X.jpg ,,,, http: / /i.hizliresim.com/Vl86Yn.jpg but luckily, this door motor is the same as renoul 9 broadway door motor .. that is, I was able to fix the middle doors 10 + 10 = 20 tlye ... I opened the inside after the engine was removed. I think the engine is burned out and can't do the first move, it turns when it turns by hand .... anyway. The engine from the r9 is exactly the same, I solved the cap connected to the cap wire and opened it and changed the cap plastics .... http://i.hizliresim.com/Jp86D5.jpg .. http://i.hizliresim.com/OR8Bvn. jpg .... http://i.hizliresim.com/zmOYjR.jpg .... then I fixed the section I sheared and put it back in place with screws and bolts shown in the picture ..... http://i.hizliresim.com /blZYZG.jpg ... http://i.hizliresim.com/dnl0l7.jpg .... http://i.hizliresim.com/58E2ED.jpg ... http://i.hizliresim.com/ AA8g8z.jpg ...
Now ... when I disassembled the rear trunk lock, I saw that its engine was completely burned and locked ... I will replace that engine myself ... but the front engines are different ... that is, they are completely closed, the engines are inside. I'm afraid I will disassemble if I disassemble ... now do you disrupt these front door centers ,,, and all the engines seem to be burned ... Those who understand a little bit of electricity know that this is difficult and illogical .. I think these engines are connected in series .. I thought it was parallel connected. .. and how does it not fuse anyway .. 30 amp normal insurance .. I'm waiting for the opinion from friends who have an idea ... thanks .....
08.05.2020 19:09 # 2
arslanalp
I guess there is no one ... anyway ... I took care of the middle and back doors ... the engines were completely burned ... how could I not get burned like this ... I tried to disassemble the front door today ... but unfortunately this is much more composite it has a structure ... i think i'm good at mechanical issues and is prone to hand but i thought i couldn't get it back sometime ... anyway i finally got it back and put it back on, but it was really hard. the part where I have the motor and the sensors is in a plastic casing, I did not open that part .... the result ... front lock centers, very complex materials. If you do not understand these things, do not bother ... let's come to what do I do? very simple .. I will bypass this mechanism from the outside ... I will tell you how to do it .... http://i.hizliresim.com/M6bq99.jpg
http://i.hizliresim.com/qr0b1g.jpg
http://i.hizliresim.com/xbjo2d.jpg
