partner control problem
08.05.2020 16:36 # 1
mahsun494
I have a problem like the control top keys have been removed and we opened the buttons with quotes due to the absence of the keys and we broke the buttons, we bought a new container and the button and a part of it was faulty, but & nbsp; unfortunately, a malfunction has occurred, we keep it for 10 seconds, the doors open normally, closing 10-20 minutes later, the doors do not open and do not close. We held the key for 10 seconds while holding the contact, the reason why it pressed for 10 seconds coded the key, but unfortunately he said he couldn't make a room, he said he forgot to code, he took it to another person, he said he takes the key measure for thieves, but I did not tell you why I need your help, thank you in advance
mahsun494 2012-02-23 08:46:35
08.05.2020 16:36 # 2
Cmoss06
If the part that has malfunction does not have an equivalent piece, it is a similar piece.
08.05.2020 16:36 # 3
mahsun494
I say exactly one piece, I wonder if there is a problem in your brain
08.05.2020 16:36 # 4
the changing part may be chip, I do not know if you have a partner, but I did not put the chip in my commander, I couldn't start the car for 2 days, I thought it was doing air, then my master came to his mind, thank you
08.05.2020 16:36 # 5
mahsun494
As I showed in the picture, the chip should be in the middle, it has not changed
