partner airbag lamp started to light
08.05.2020 17:35 # 1
baha1907
Hello friends
& nbsp;
When I started the car since yesterday, the airbag light that should turn off is constantly on and when I lift the car & nbsp; he beeps shortly and his voice is heard. What did I have to do when I stopped and stopped ...
& nbsp;
I'm waiting for your help.
08.05.2020 17:35 # 2
Serkan
The airbag plug may be loose from the Com2000 (the unit under the steering wheel and the airbag connected), the airbag coil may be broken, if there are side airbags in the seats, the sockets may be loose.
08.05.2020 17:35 # 3
baha1907
Would you suggest what I can do without going to the service?
08.05.2020 17:35 # 4
Serkan
You can control the sockets by removing the cover under the steering wheel, you can control the sockets under the seat, there is not much else you can do
08.05.2020 17:35 # 5
baha1907
[QUOTE = 307bursa] [QUOTE = Serkan] The airbag plug may be loose from the Com2000 (the unit where the steering wheel controls and airbag are connected), the airbag coil may be broken, if there are side airbags in the seats, the sockets may be loose. [/ QUOTE]
If you check what my Serkan teacher said, plus if your linings are worn out, you can get burned information from him
I replaced the pads in September 2011 and over 20 thousand km passed. & Nbsp; When I say it can burn, I don't understand what it is burning?
08.05.2020 17:35 # 6
ErolSs
it is usually when you move the seats back and forth on the move, probably the socket is loose as friends say
I know that they delete the error message for 20 TL in the industry.
08.05.2020 17:35 # 7
baha1907
[QUOTE = ErolSs] is usually on the move when it makes the seats back and forth, probably as the friends say, the socket is loose
I know they are erasing the error message to 20tl in the industry
[/ QUOTE] < br />
Deleting the message may be a simple task, but will the airbag open in the event of an accident
08.05.2020 17:35 # 8
ErolSs
The error is caused by the cables from the sockets, the accident situation, the explosion according to the impact it took from certain places, the airbag is already seeing where the malfunction is and when they delete the message there is no problem.
08.05.2020 17:35 # 9
gozem
It happened to me in my 2004 partner, which was my previous vehicle .. the socket under the seat was loosened ... we fixed it with a hookup. I hope yours is the same fault.
08.05.2020 17:35 # 10
baha1907
[QUOTE = eye] my 2004 partner, which was my previous vehicle, happened to me .. the seat under the seat was loose ... we fixed it with a hookup. I hope yours is the same fault .. [/ QUOTE]
eywallah buddy tomorrow is an experience. but there are 3-4 cables and I looked like it looked solid ...
