Partner Adventure Park sensor assembly.
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:12 # 1
Engin Tepe
Parking sensor assembly, which we started at 5 in the evening, finished at 8:30 in the evening. Putting the element together in the bus station (manavgat) and Burak's help included: Then we put them back in place and unscrew the bumper screws and took their cables inside. There is a white dot on the back when wearing it, and it should be noted that it overlaps. After collecting the cables inside, I closed the luggage and went around. I went to the bus station. I came to Burak. I came. I came to the road. I came and continued from where we left Electricity remained. Şahin how to shape the chassis with the help of peugeot atn by taking the phone. By removing the rear right Stop, we reached the chassis and the part where the electricity will be taken. Necessary connections were made and the back was replaced. Finally, the connections were made and the assembly ended with the location and sticking of the screen and the assembly of the amplifier cable was removed with the lower plastic parts removed. The product quality is quite good, I like it. Engin Tepe 2011-10-08 15:23:03
08.05.2020 16:12 # 2
health is not in your hands but the subject I do not understand is that with the drill bit it turns out, only a small hole is drilled
08.05.2020 16:12 # 3
Engin Tepe
Drill bit large enough for device to enter.
For the silicon hood to prevent it from coming off easily with the silicon cap clamp, such as cork header.
08.05.2020 16:12 # 4
I'm going to check in at the first opportunity on weekdays, but I think it will be harm before I think of painting before wearing blue.
08.05.2020 16:12 # 5
Engin Tepe
Although it does not have a clear knowledge of painting, it is not original lady, so how do you try to paint it afterwards or if there is anyone doing it? Do you have.
Have the owner paint all of them.
08.05.2020 16:12 # 6
good luck alone, don't you pull the cables on the screen or is it wireless .....
08.05.2020 16:12 # 7
Engin Tepe
We pulled the cables under the glass door tires under the left seat, there is an amp, we put the device in the trunk with its cables. cable is too much available
08.05.2020 16:12 # 8
Goodbye brother, thanks for the explanation & nbsp; "Laugh"
08.05.2020 16:12 # 9
Engin Tepe
You're welcome bro :)
08.05.2020 16:12 # 10
[QUOTE = Engin Tepe] Although we do not have a clear knowledge of painting, it is not the original lady, so how should I try to paint it afterwards or if anyone does it?
Try paint does it have the same sensitivity as the others.
Have it paint it all. >
There's a losing in that one, but as a result, I want it to remain black for now so :)
08.05.2020 16:12 # 11
iibrahimm
& Nbsp; & nbsp; greeters, I bought it from the device that the vast friend has received tonight, but it takes some corpse to pierce the bumper vehicle 307 on the bumper & nbsp; do you have certain places or if you die with the meter & nbsp; you wear my corresponding places
& nbsp; & nbsp; Are the sensors affected by paint? how would the lady in the red bumper be not so good
08.05.2020 16:12 # 12
Engin Tepe
08.05.2020 16:12 # 13
save your health health & nbsp;
08.05.2020 16:12 # 14
good luck with your brother sensor
08.05.2020 16:12 # 15
[QUOTE = HuseyinTurk] let me look at the first opportunity on weekdays, but I think it would be harm if I think of painting before installing the car blue? [/ QUOTE]
if I remember wrong, I heard that they painted with it, but I will not know my truth --- is there any other alternative than painting ???
08.05.2020 16:12 # 16
Engin Tepe
Alternative to use original, other than painting: D
Thanks guys. It was very easy to set up. If I was aptic, everyone will do. : D "Embarrassed"
08.05.2020 16:12 # 17
Engin Hand Health Brother ... You Have Done Well ... "Thumbs
But Do You Adjust The Dimensions Of These Pictures Too Big Loaded Kasma .. I don't understand ...
08.05.2020 16:12 # 18
metin
vastly, how good is that baggage (:
08.05.2020 16:12 # 19
Engin Tepe
Brother Luggage that day was dead. The place of those messy materials was in the place where the cable installation was pulled off. When we dismantled the place with the chipboard, we did not distribute it. You wouldn't see it normally. : D "Embarrassed"
08.05.2020 16:12 # 20
Burak07
Thank you in the help, brother: D, otherwise I would walk home: D: D & nbsp;
Page : / 2
