Partner
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 20:54 # 1
Digorlu
slm friends I have a partner hill 2009, when my car starts first 150 150 meters later it stops on its own, first a cut is interrupted, then it stops, how many masters I got, the problem is not solved, especially when the car goes home in the evening, it is running in the morning and it is happening when I return home, it is on my first passage. It works after a little bit of starter, sometimes it does not work. It is very difficult to start, it starts to run, but the engine does not start, it looks like diesel is running out, but there is diesel, it is not used as much as you want all day long.
08.05.2020 20:54 # 2
breakbeat
Can there be a problem with diesel hoses or diesel pump
08.05.2020 20:54 # 3
Digorlu
I don't think because the masters checked it too
08.05.2020 20:54 # 4
Digorlu
Especially in the morning and in the evening, it is doing in the morning and evening.
08.05.2020 20:54 # 5
Digorlu
When it does, the starter is pressing but the engine does not ignite. It is necessary to deal with it. The engine is running.
08.05.2020 20:54 # 6
breakbeat
It still felt like fuel to me. I think when the car waits, the fuel goes back to the tank, the hoses remain empty. The fuel reaches the engine as you start and do it. Before you start the car tomorrow, would you try to squeeze the manual diesel pump under the hood several times and then start it. Something similar to the rubber spout's air discharge pump.
Also, they may have bought the diesel filter side industry or did not install it properly. I had a similar problem with my Megane 2 car. They installed the wrong diesel filter in the vehicle.
