partner 2006
08.05.2020 17:47 # 1
mustafasevik
slm friends vehicle partner 2006 2.0hdi problem engine is running a little noisy and the car does not go as if there are 200 engines go to the service air filter is clogged changed cleaned oil oil filters are cleaned there is a little whistling sound in the turbo, we save it with the balance adjustment in the tubo, so there is no problem in the tub, the car injector when it enters the computer The error is giving the service is either clogged or broken. I would like to consult you. I would also like to consult the exhaust in the first run, it throws white smoke from the injector. Thank you in advance, everyone, Ramadan.
08.05.2020 17:47 # 2
cocomo
Exactly I also have 2005 partner 2.0 hdi.
I had the problems you mentioned. all the injectors were failing. I had cleaning all 4 injectors had improved. Do not neglect the turbo whistle because I ate a complete engine because I care about the turbo whistle.
detailed story
08.05.2020 17:47 # 3
mustafasevik
We will have it done now, but I hope the vehicle will take the old traction, so I don't think it will make a whistling sound, thank you brother.
08.05.2020 17:47 # 4
cocomo
Let me tell you that when the injectors of my vehicle were made, the traction was back in the past.
Some time passed, the turbo started to whistle.
Then the vehicle fell out of traction again ...
Think of your whistle like this
there is a compressed air vacuum. in turbo hoses. it means empty air that is emitted from the whistle manifold or turbo without being exposed to pressure ... so the air that came out in that whistling sound was actually the air that will come back to you as a performance thanks to the turbo. but I'm wasting right now because of the whistle ...
I couldn't exceed 30 in the last time of the whistling turbo ... I couldn't overtake the police patrol vehicle at night.
the vehicle had turned into a diesel without a flat turbo.
so I say that whistle drops it from a traction. you will be amazed .. you can't use the vehicle for too long anyway. The next step is the malfunction lamp lights up and you have eaten the engine ... after complete recess.
Cocomo 2013-07-12 18:39:44
08.05.2020 17:47 # 5
mustafasevik
I got it, bro, thanks for the information.
