Partner 2001 dashboard
08.05.2020 21:11 # 1
Ez511
Firstly, good evening, friends
I bought a 2001 partner 1 month ago, I am satisfied with the car but recently it started to make a problem
And I showed you a few masters. Did anyone say anything clear, can you help me, or can you suggest a master who can really help?
The digital indicator also had the key phrase and the clock was wrong, I went to the electrician and put out the malfunction lamp
He set the clock at first, but there was nothing to start the car and after 2-3 km of roads, the gostege panel started to cut off the power and it did not go back any more. No hand is working.
08.05.2020 21:11 # 2
GokhaN
it looks like the dashboard needs to be repaired
08.05.2020 21:11 # 3
Ez511
Thank you, my teacher, I found a brain worker and said, I will inform you, but he is ill.
08.05.2020 21:11 # 4
GokhaN
[QUOTE = Ez511] Thank you, my teacher, I found a brainbuster and said, I will inform you, but I think he was ill [/ QUOTE]
it happens when cars are old normal
