Partner 2.0 HDİ Oil Selection
17.07.2020 20:41 # 1
Metsuke
Hello; I have a 2006 model peugeout partner 2.0 hdi combi vehicle. I bought it about 3 months ago and when I asked the owner of the vehicle which oil was used, he said he did not know. Usually 1.9 diesel option filters come out, are the filters the same? I would be very happy if you could help.
18.07.2020 02:58 # 2
Partnercii
First of all, greetings.As oil, I did a little research for your vehicle and I saw that the oil viscosity suitable for your vehicle is usually 5w-30. You can understand this from the photos below. Nevertheless, when buying from the part, say that you are buying for the 2.0 HDI engine.
20.07.2020 08:58 # 3
Our friend has given the necessary information, teacher. Notice that their filter kit differs from 1.9 flat diesel. 5w / 30 as oil is good
30.12.2020 23:43 # 4
Outlander
Greetings. For 2003 model 2.0 HDI I am using Total 5w40. This viscosity is also recommended in the booklet. I am very satisfied. Mobil 1 5w40 is also very good.
01.01.2021 18:26 # 5
Diver28
Since I found this as a subject about oil, I did not open the subject again. I have a 2005 model citröen c3 1.4 16v semi-automatic car. I am very satisfied. I use Total Quartz 5-40 as oil. Some masters are insistent at 5-30 for some reason. I know that they recommend 30 oil for euro 5 engines. In such a case, when I remove the engine hood, there is an oil label on the front panel. It says acea a3 / b3-a5 / b5. What does it mean? Thank you in advance for your valuable comments.
