Partner 2.0 HDI major issue
08.05.2020 17:23 # 1
cocomo
Greetings.
PROBLEM SOLVED. I EXPLAIN THE FOLLOWING MESSAGES YOU CAN READ HOPE BENEFITS:
My vehicle Partner 2.0 HDI 2005 model 122.000km ..
< br>
I just got it from Göral. I also have a 6-month service warranty.
When I first received the vehicle, there was no problem. black smoke was coming but I wasn't there because diesel was custom. I am a diode, I have a tuning tool. & nbsp;
I was not in a hurry because I started a new business because I bought a lot of masters, and before I bought the car. & nbsp;
< div> those in the lagoon are like girls, our vehicle has been sold from scratch since all the heavy maintenance has been done. When I gave a 6-month warranty, I did not want to worry too much ...
but after a week has passed, the troubles started .. .
When I first start the car in the morning, I do not move it for 3-4 minutes & nbsp; to warm it up.
but at the same time, it blows an incredible black smoke. and the real problem is; running jerky. rough running tool ... like snarling ... & nbsp; trilil trilil works by vibrating in the range of 0-1500 revolutions.
& nbsp; As soon as it falls below 1500, it starts to vibrate like a car with LPG. If it is less, it will stop as if it is shaking ... it gives a little gas and trembling stops when it exceeds 1300 1400 cycles. & nbsp; it doesn't flicker when you run it hot during the day .. it only happens when it's cold. Anyway, I said it is from the number of diesel. vibrates when it is cold .... & nbsp;
but when it is parked in the shaking vehicle, the vehicle vomits and improves a little when it is loaded to idle gas and 3000 revolutions. working idle returns to normal. tremor decreases ... but it leaves a big black stain on the asphalt. Exhaust vomiting institutions ... almost can't go. Her hand brake is pulled down. & nbsp; cycle is not rising. It is very difficult to progress on the slope or something ... I make a huge cloud of black smoke behind me and the car starts to open and go away ... as if it had released the handbrake.
There was something clogged at once when it was in 2 gear He spits like a spit and starts to go like a car and a monster.
the same terane every morning. & nbsp;
but black smoke never stops. I walk around with smoke all day long. I travel with dark clouds like batman's car ...
I don't understand much from these works ..
I have no time to go to service. I work for 15 hours a day. I can't find time and show it to the service.
what do you think is wrong? & nbsp;
can one of the filters be clogged? & nbsp;
Can my injector settings be problematic?
I have been using the vehicle for 500 km or more. I bought very recently ...
my fuel consumption: I bought the last 100 pounds of fuel. I went to 220 km or so. & Nbsp;
I have no problem of oil reduction, I do not have an oil problem for now.
. & nbsp;
regards.
cocomo 2013-07-12 14 : 12: 15
08.05.2020 17:23 # 2
Alicilik
If the filters have just changed, look at the catalyst, and my skin may be blocked.
In addition, the mix value incoming air setting may be affected. If fuel is stuck with a little air, it can cause it.
08.05.2020 17:23 # 3
cocomo
Isn't it an unusual sound if the catalyst is clogged or there is a problem with the catalyst? I don't come too.
08.05.2020 17:23 # 4
Alicilik
[QUOTE = cocomo] If the catalyst becomes clogged or if there is a problem with the catalyst, is it unusual?
Since it is one of the parts that filter the blackhom, that part came to my mind.
In addition, the fuel mixture ratio as I said important. Sometimes even the quality of the fuel you get can affect the vehicle.
08.05.2020 17:23 # 5
syn022
It seems to me that your car's fuel is a bit high. 2.0 HDI is a robust engine, in fact, it is not easy. I think it might be related to the fuel you get. Recently, we bought diesel from my father's vehicle in Istanbul, it could not exceed 140. When we came to Edirne, we bought diesel from the place we know and the car was back to normal. My advice is to change where you bought diesel first and clean an air filter. If not, I think it might be from injectors. & Nbsp;
08.05.2020 17:23 # 6
ahmet_bjk
When running in cold weather in the morning, the misfire is normal 1-2 & nbsp; wait at idle & nbsp; will recover when it gets warm.
Another reason for misfire may be from the fuel you get. ;
08.05.2020 17:23 # 7
Bugra
When I read what you wrote, my teacher is about all of the vehicles with diesel engines except for tremors. Agility in diesel vehicles is a little bit about delivering a lot of gas in a half clutch. No need to wait for the bidet turbo in the morning. you just have to wait a little while when you stop your vehicle, the turbo to reach normal rotation speed. If you cannot adjust the clutch ii, the accumulation in the vehicle will not be able to go even if you press the gas. In this accumulation state, that is, if you have braked as you said, when the vehicle is loaded with a bit of gas at half a clutch, the turbocharger of the vehicle will start rotating and your vehicle will be picked up. I laugh at the black smoke because my neighbor bought 0 new safes doblo, walking around with the bags of the seats. There is a black smoke on the first departure in the morning .. no such thing. that is, smoke diesel vehicles are indispensable! unless it is excessive ... respect.
08.05.2020 17:23 # 8
cocomo
Thanks for the answers, friends
tremor happens in every cold vehicle yes you are right, but mine seems unusual for me. he throws the car behind him can't see his front. It's not like the classic diesel smoke, so ..
I can go half a clutch, but until I get the vehicle cycle. then the vehicle suddenly vomits as if & nbsp; and it starts to open and go. the same thing every day.
the service road seems to be found, hopefully find someone and drive around I can send it
cocomo 2013-02-26 14:10:22
08.05.2020 17:23 # 9
ahmet_bjk
Now it came to my mind. In 2001 model partner, I changed the gaskets of the diesel pump. After this process, they could not adjust the idle of the vehicle well. Idling was low. I do not know the others, but until 2001 the car warmed up, the engine adjusted its idle according to the air temperature. So even though the weather was not cold, when I first ran in the morning, it was misfire.
So the reason for shaking may be idle adjustment too !!!
08.05.2020 17:23 # 10
baha1907
I also have partner 2.0 hdi. he makes great effort when starting the car in the cold morning. All the maintenance was done on diesel, but I give it diesel and I run it for 2 minutes in the morning. I think it will be useful to get würth's injection cleaning fluid. I make a full 400 km road with 110 pounds of diesel, with a speed of 100 km. Your information. Reviews
08.05.2020 17:23 # 11
cemoandcemo
We had 2.0 hdi partners for 5 years. The tremor event is present in all of these vehicles. But I have no information about the black smoke throwing event.
08.05.2020 17:23 # 12
cocomo
Meanwhile, the vehicle also kicks in gear shifts.
When I switch to 1-2-3 gears and give gas, it gets to the monopoly gas.
Most of the time, I can still make a half clutch even on a straight road. There is something clogged in the car. I'm in a very difficult situation.
08.05.2020 17:23 # 13
cocomo
cost me 4000 lira for the car they sold badly (not allowing test driving) !!!
4 injectors would change,
EGR would change.
the glow plug would change.
I am thinking of filing a lawsuit will be in the hands of the notification very soon.
08.05.2020 17:23 # 14
baha1907
[QUOTE = cocomo] I took it to Göral.
they charged me 4000 dollars for the car they sold badly (not allowing test driving) !!!
< br />
4 injectors will change,
EGR will change
the glow plug will change.
is not covered by the 6 month service warranty, I was officially defrauded.
I am thinking of filing a lawsuit very soon.
< br />
What ordinary people are there wow
08.05.2020 17:23 # 15
cocomo
Be the friends, do not buy a car from Ankara Göral. My victimization is great. & nbsp;
When I said that I bought diesel from Shell, I would like to claim 4000 TL by making a defense like I wish you bought gas from Opet .... officially ..... nonsense.
all my rights were deleted as soon as I bought the vehicle. and I made 4000 pounds of damage. there is no turning back ....
08.05.2020 17:23 # 16
cocomo
It was edited to prevent SPAM. Cocomo 2013-03-29 01:10:49
08.05.2020 17:23 # 17
cocomo
Instead of being piled in the Göral, I took the vehicle to the unswerving industry. div>
cocomo 2013-06-28 00:49:01
08.05.2020 17:23 # 18
cocomo
I am writing to update my friends so that others can also be informed. In my last last message, the vehicle was improved. The car was going with 20 and now I took it back to its unswerving master ... from the turbocharging and the melting of the pistons. the pistons are lubricated. pistons melted. I rebelled with a swear of doom and a sense of entanglement by GÖRAL and I instructed the master to do whatever it takes. in short, the word engine of the car landed. I entered the competition. I have been writing for zero weeks since the beginning of my adventures in the industry for two weeks. / sensorbright stop lamp replacement, complete oil change, warehouse cleaning, wicked rot balancing4 tire renewal, front brake pads renewal exhaust hanger replacement, while still touching the glass film, the engine block is the ear exchange, the front discs are sandpapering, rectification, refiner, 4 carbon cleaning, injector dozens of little ones that don't need to write piece gasket rubber zart zurt.it is like a joke but all of them were done to the car.the car has been reset now.the cost of all of them kept 5.800 including parts and labor.If I had it done in GORAL, it cost more than 10 lira.No work in the old version of the car anymore. I do not load the vehicle more than for reasons such as the new engine time, but even if I do not load it, I am watching the rear of a passenger car without rearview with 4 gears on steep ramps. on steep slopes, I'm going to make a selector horn. Common interpretation of all the masters, brother GÖRAL pushed you officially. I wish you brought it to us. If we saw this car, we would have been scrapped ... If we knew this business, this car would never be at 122,000 km. they made comments on at least 400.000 km. in particular, I was defrauded by kalam GÖRAL and the 2005 model 2.0 hdi partner cost me 22.000 TL with the engine renewal. Every morning I ride the car, which is sold by GÖRAL as a girl, saying that all the heavy maintenance has been done. The car crawled in the industry for 10 days. And I have officially carried my materials on my back for 10 days .... whether I am in the power of my work or 6 thousand liras fleeing me. Do not cry if you can lend your car to the nation, do I know if Göral says "there is nothing we can do, sir", I am burnt! cocomo2013-06-28 00:49:47
08.05.2020 17:23 # 19
Have a lot of history. Take the innocent of the oppressed people, There is a withdrawal point in this business. Do not worry, no one will be left with anyone.
08.05.2020 17:23 # 20
hLL
It is necessary to scrutinize and weave frequently. After all, no one is our father's son. There are thousands of people falling into this situation. I have recently read 140 thousand thousand, the man who learned to get a taxi that knocked down 600 thousand after a month. I can't find anything to say other than to say yuh to these crooks. Get well soon. I hope you can use your vehicle without any problems and trouble-free trouble for years now.
