Partner 2.0 Hdi Does Not Pull On The Hill
08.05.2020 20:47 # 1
erten07
Partner 2003 2.0 I have a vehicle, the vehicle falls on the ramps, no matter how fast I come
They made the turbo sized, they said there is no problem
I changed the printing pad again the same
I cleaned the injectors
I got the pump installed
I looked at your engine, they say all good, my problem is not solved
car is okay no problem on normal road
If there is a friend who has this problem, I would appreciate it.
08.05.2020 20:47 # 2
Other than these, the diesel pump can be controlled and there may not be enough pressure. or when you are going uphill, when the diesel is low, the pump cannot draw enough. Fill the tank full and try it like that. Second possibility was catalyst control.
08.05.2020 20:47 # 3
ggitaristt
It feels like a turbo activator or a turbo pressure sensor and hoses ..
If the activator normally opens but does not fully open at high speed, it may be the problem you call turbo, I have encountered with examples in the past.
You can have my counters checked in a good turbocharger .. I don't think there will be a malfunction or replacement, just the setting.
08.05.2020 20:47 # 4
erten07
Egr canceled
catalyst and muffler installed
diesel full or half none doesn't matter always the same
they took the turbo and measured it in antalya turbo they said no problem
08.05.2020 20:47 # 5
erten07
I did not have a problem with the diesel pump.
08.05.2020 20:47 # 6
ggitaristt
The turbo will not be removed or not, my friend got it wrong .. Connect the vehicle to the controller .. Give gas where it stops, how much pressure does the activator draw and reach the road. ..
They said no problem to my uncle's 407 car. They made the activator adjustment 4-5 times. They said that the activator is working. they put it on ours, the car got a direct 110 hp ..
Arrangement: Oh, I am not saying that this is the problem of your problem, but 2 full days were dealt with our car, they were able to improve the car a little bit. At last, I was so tired that the car got stuck in my mind.
The reason I was stuck in my mind was that someone had happened to him before.
ggitaristt 2018-03-10 00:09:27
