partner 2.0 hdi 90 hp fuel consumption
08.05.2020 16:01 # 1
murtiss78
partner 2.0 hdi we got 90 hp 1 and a half weeks ago, 28 cents a kilometer out of town lit a lot came to us
Isn't it too much for you?
08.05.2020 16:01 # 2
tayfundoner
Did you get a vehicle 0?
08.05.2020 16:01 # 3
Engin Tepe
130 kmh average from Istanbul empty Antalya,
The empty warehouse filled to 215 TL and 1130 km of it, the rest of which is 900 km.
an average of 0,18,019 bird.
but 215 TL in Antalya, 800 800 km inland, quiet use but 750 max.
Engin Tepe 2011-08-22 14:45:42
08.05.2020 16:01 # 4
Engin Tepe
[QUOTE = murtiss78] partner 2.0 hdi we got 90 hp 1 and a half weeks ago, it was 28 cents a kilometer out of the city.
By the way, if you introduce yourself from the member promotion section, it would not be bad ... Engin Tepe 2011-08-22 14:54:49
08.05.2020 16:01 # 5
emin08
Fuel consumption is a bit like it. It burns 0.22 - 0.23 TL in calm use in the city. If you just bought the vehicle, I recommend you to replace the air filter, fuel filter, etc.
08.05.2020 16:01 # 6
hakelbery
Did you give the right to Aslan, it burns 32 cents in the city. Attention is in high performance use ... I have not been able to measure the other, calm use until now, I can not patience so much while I have this power ... Gülme
08.05.2020 16:01 # 7
cocomo
parter 2.0 hdi
With 100 tl Eurodiesel, 240 km of light was illuminated on the roads, which are abundant in the city.
Do you think it's normal?
08.05.2020 16:01 # 8
Secks
Hodja is from the same vehicle, 2005 model, just over 100 km of aggressive use on roads with abundant ramps, it goes beyond 300 km. The extra-urban km is around 23-24 cents.
08.05.2020 16:01 # 9
cocomo
My teacher, the light is on like 240 km. How many kilometers do they go after the light is on? I just bought it and never had a test. Do you think mine burns a lot?
08.05.2020 16:01 # 10
Secks
After the light is on, it goes 50 km more. I recommend that you take diesel when full light is on, reset the meter and measure again until the light turns on. If it burns at 240 km too much, check for an air filter, etc. It may be time for maintenance. And how many kilometers is the vehicle?
08.05.2020 16:01 # 11
cocomo
I do exactly that, as soon as the light is on, I take it and reset it.
vehicle 124 thousand. we built a new engine, almost no parts left ...
[QUOTE = Cocomo]
4 glow plugs
EGR valve
lubricating nozzle 4 pcs
piston suit
sleeve bushes
arm bed
main bed
crank
valve's
gasket set
cylinder head gasket
oil pump
zero turbo
oil / air filter
timing set
V-belt
clutch kit press pad
block carrier
gearbox oil
front axle bearing
gear stick
sliding door lock / sensor
burst stop lamp replacement
complete oil change
warehouse cleaning
clear rot balance from start
injector 4 pieces of carbon cleaning
injector nozzle 1 piece
catalytic converter catalyst cleaning
air conditioning gas regeneration
steering oil replacement
clamshell work
recreational workmanship
pump labor
lathe
but the fuel still hasn't dropped ... I don't use aggressive or anything, but the roads I use are always up to 80 percent. How many kilometers of light are you on? With 100 TL?
Cocomo 2013-05-06 23:31:05
08.05.2020 16:01 # 12
Secks
I always use it on slopes. Ankara / Dikmen who knows :) My vehicle has just over 100 thousand new 2005 model. I exceed 300 km with 100 lira.
08.05.2020 16:01 # 13
baha1907
According to my most recent measurement, I went to the full road of 576 km to full 150tly ... half inside the city half outside the city, ie average account: between 26 and 27 cents per 100 km.
Of course, if it is only hit out of the city, the rate drops very easily under 25 cents.
Of course, the 5th gear should be around 100 km / h. After 110, the burning becomes more informative.
08.05.2020 16:01 # 14
baha1907
this weekend I will buy diesel from the shell again and then share it again, friends ...
08.05.2020 16:01 # 15
baha1907
When my warehouse was full, I traveled 708 km and filled the tank again.
I bought 206 diesel
So 0.29 kurus 100 km road I went to 29 TL (inner city out of town mixed)
