Partner 2.0 HD did not work after oil change
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 21:10 # 1
Pejo partner 2005
I made oil change of Partner 2.0 HDI diesel vehicle. It worked on the first starter.
Then we stopped the car and when it wanted to start again, the car did not work.
The starter motor gives the first cycle. However, the engine does not work.
I would appreciate if you give information & nbsp;
08.05.2020 21:10 # 2
talip206
The oil phenomenon may have been a coincidence. Things to look for from cheap to expensive (easy to difficult); & nbsp;
1. If there is a spare key, try running it with it.
2. Whatever is the level of diesel in the tank, the dirt may be clogged or aired.
3. Normal & nbsp; and have the Maxi fuses checked. When some fuses blow out, the starter starts and does not ignite. (For example immobilizer related fuse or diesel pump fuse)
4. It may not ignite due to the crank sensor. Move the car a little while in gear & nbsp; try running it. Crank sensor position changed.
5. There may be a problem with the diesel pump or injectors.
