Partner 2.0 does not eat gas
08.05.2020 20:51 # 1
Pahca1990
sa friends
I have Partner 2.0 hd. The light goes out after a few days, but it keeps recurring. The error code says diesel high pressure flow regulator on the computer. Masters in the industry. Let's change the fuel filter, let's add a bidet. What do you think we do?
08.05.2020 20:51 # 2
Selcuk55
There may be a situation related to a .fuel regulator or a diesel pump.
08.05.2020 20:51 # 3
Pahca1990
some may be turbo valves. Some of them says the warehouse has messed up. Does anyone have such a situation?
08.05.2020 20:51 # 4
Selcuk55
I think it is very unlikely that dirt will come from the tank.
08.05.2020 20:51 # 5
First of all, welcome to us. If it does not exceed 3000 cycles, it is probably due to the turbo solenoid valve.
08.05.2020 20:51 # 6
Pahca1990
We're [I'm] glad to be here
It does not exceed 3000. The pedal is wasted. When the gear shifts, it gets gas again.
08.05.2020 20:51 # 7
[QUOTE = Pahca1990] Hoşbulduk
then your distress turbo electrovanada teacher should not be a very expensive piece. It would have a price between 100-150 TL.
08.05.2020 20:51 # 8
Pahca1990
finally we found the solution, the air flow meter is broken.
Diesel high pressure monitoring flow regulator, friends receiving intermittent error in stop. Air flow meter should be changed.
08.05.2020 20:51 # 9
Selcuk55
I said, say flow meter Wink Anyway, I am glad that the problem is solved.
08.05.2020 20:51 # 10
I am glad that your problem has been solved.
12.02.2022 17:07 # 11
gepi usta
Check the electrovalve and vacuum line. cable rot may be leaking
19.09.2024 02:36 # 12
Musa25
Hello, did you buy the original air flow meter? The masters say it is not compatible with the aftermarket. I am confused.
