Partner 1.9D Partner
08.05.2020 19:14 # 1
EmrahPartner
Hello friends and craftsmen, I just joined you, I just bought the vehicle 1.9D 2001 Model Partner is similar to my problem but a little different
1 - When I start my vehicle in the morning, there is no problem and misfire in the first 20 seconds. The engine is working normally. The smoke extraction process begins after the motor starts after a certain period of time, that is, after the warming up, after the motor warming up again, the engine knocks at certain intervals, but it does not feel much. no smoke comes out. While the engine is cold, the vehicle shakes at low speed, but if I increase the speed, there is no shaking, for example, there is no shaking when the engine is cold, but when I find 2500 rpm in the 3rd gear, there is shaking back and forth if I take my foot out of the gas or if I lower the rpm a little bit, I shake the fuel back and forth. I came across the ones who experienced the problems from the injectors and solved them by adding additives, but I do not want to make an eye when I say eyebrows, I wanted to get ideas from the forum by thinking that if someone has solved this problem or shared it, they will definitely share it.
08.05.2020 19:14 # 2
EmrahPartner
Nobody answered, but my problem is solved
I showed my car to about 20 masters and bikers and pumpers came up with different ideas.
The pump said 90% pump and said that there will be a fee between 400 and 1000 TL.
The biker said that the engine of this vehicle is exhausted, you will have to have a thousand engines
The other biker takes the air of the vehicle, the diesel filter needs to be replaced completely, he said.
Another pumper may be doing the urination of the injectors, he said.
And in other masters they kept repeating things similarly.
Conclusion: Since I knew that I had to start from somewhere, I went to a pumpman I never went to and I told him about the problem of my car. What I said was a problem related to the engine of the vehicle. After waiting for about 2 hours at the priced starting point, the engine was a little cold and we wanted to run and check it. it was assembled and I was told to start the car as soon as I started the car, after 15 seconds, when the same situation started, they said turn it off and it was time to ignite that my car's synthesis was lost. They said that they did not do it. They brought a device there, checked it and adjusted it to the sentence, and all my problem was resolved. The sound of my engine changed everything. I was amazed that I was a motor master for so many years, I took my car to the masters who say that I have a shop in the industry for many years. Delphi Tanlar San Tic. Ltd Şti, thank you for solving my problem at an affordable price.
08.05.2020 19:14 # 3
xmen
glad to solve the problem ... bye
08.05.2020 19:14 # 4
oguzhan29
glad to have your problem resolved
