Partner 1.9 motor fan problem
08.05.2020 17:54 # 1
ebucihad
hello 1.9 I have a 2004 model partner. When I look at the harleet indicator half an hour after I run it, I see 1 line above 90 degrees, but the fan does not turn on. While running, the rear wiper is active once it stops. Could it be because of the error in the electrical system? Or what are the first things to do. Thank you for your attention I am waiting for your answers.
08.05.2020 17:54 # 2
kasirga16
Aleykümselam teacher, I had a partner in me, as well as 1.9 2005, since the pejoes like to work at high temperatures, they usually turn on fans at 100-110 degrees. Put the car in neutral and load the gas a little bit. After 100-110s, the heat has turned on the fan, I remember that there is a two-stage fan, show it to the service if you are not sure. When operating for the first time, you can make the rear wipers start and stop from the settings on the arm where the wipers are controlled.
