Particulate Filter and Engine Malfunction Light ???
08.05.2020 20:19 # 1
blnd
Priorities hello everyone. I bought a Peugeot 308 1.6 Hdi 92 Active 2013 model car from Hatay on Monday In expertise, engine performance was 88%. While coming on the road, I was warned to follow the instructions to fill the particle filter, but when I looked at the booklet, I could not find any instructions. I connected it to the computer, the master diesel filter is clogged. I'll take it back to the master over the weekend. I am waiting for the suggestions of friends who have experienced this problem before ... Edit: I am afraid to use it like this because it is my first car so I can do more damage LLL
08.05.2020 20:19 # 2
First of all, welcome to us. good vehicle. May my Lord show no trouble. This is usually the case when driving the vehicle at a short distance, usually the vehicle stops without warming the engine. As a result, the accumulated institutions are unable to get rid of this error and also result from bad fuel. Use your vehicle a little revolving, make a long 1-2 hour road, these errors will pass.
08.05.2020 20:19 # 3
erk4n
Possibly, the filter in the catalyst may have connected to the soot.If there are many problems, you can have the catalyst removed and cleaned and then it will not cause any problems in the long term.
08.05.2020 20:19 # 4
blnd
Thanks for your valuable comments, friends ... I will try to solve this problem as soon as possible and enjoy the peugeot. When it is the first car, the person is concerned about it, whether I did something wrong;)
08.05.2020 20:19 # 5
uzunca961
I had a similar problem. When I bought my car, the particle filter additive was malfunctioning. This has nothing to do with the diesel filter. As Sonerkyl said, soot accumulation occurs in the particle filter. If you use cycle, it will already be cleaned automatically for a while.
08.05.2020 20:19 # 6
blnd
Thanks for your information, hodja. For now, the fault light is off, as you say, in order to clean the particle filter itself, which I will use the vehicle at high speed in 4th gear. Thumbs Up
