particle filter danger of clogging. (Solved)
08.05.2020 20:54 # 1
samet2461
Meanwhile, when using the new e-hdi 308, the particle filter is in danger of being blocked. I follow the suggestions ”on the road computer. Generally, when I use the vehicle, it gives this error. What should I do. What is the intention of the proposal, I could not find anything in the vehicle booklet
Tell me from the trabzon - I glued it to the zigana, no mistake, no problem Big smile
samet2461 2018-06-10 20:30:02
08.05.2020 20:54 # 2
onlycihan
in fact, when using the cycle, this filter needs to be cleaned so I know
08.05.2020 20:54 # 3
Selcuk55
If your particulate filter is obstructed, gas cannot be released when the vehicle is pressed, connect it to the new system filter cleaning machine and clean it.
08.05.2020 20:54 # 4
samet2461
[QUOTE = Selçuk55] Your particle filter cannot empty the air when the gas is pressed into the vehicle, connect it to the new system filter cleaning machine and clean it. [/ QUOTE]
However, there is no problem in driving the vehicle. When I use it normally, it does not give this error. 2 seconds after taking my foot out of the gas to cyclic user gives this error I tried today
08.05.2020 20:54 # 5
Tunahanhos
My car had the same problem 1.6 hdi envy 2011 model. I connected it to the computer 3 times and burned it, but the same problem continued. Finally, I had the filter on the exhaust and went and wiped the particle system with the software. I have been going for 1 year without any problems. And it passed after the exhaust inspection. I advise
08.05.2020 20:54 # 6
GokhaN
[QUOTE = samet2461] when using the newly purchased e-hdi 308 “occasional particle filter is in danger of clogging. I follow the suggestions ”on the road computer. Generally, when I use the vehicle, it gives this error. What should I do. What is the intention of the proposal, I could not find anything in the vehicle booklet
As a matter of fact, if you have gone 100 km in fixed gear between 3000-4000 rpm, nothing remains
