part replacement suggestion. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 18:24 | # 1 |
| 08.05.2020 18:24 | # 2 |
ahmed206 |
I bought the technorot front team last year, I'm glad, he does his job in Turkish.
| 08.05.2020 18:24 | # 3 |
ahmet_bjk |
I think if you can, don't be surprised by the original |
| 08.05.2020 18:24 | # 4 |
TaZ |
be careful when buying shock absorbers, the right left and right outer labels of all the parts are printed wrongly from the left and the left left.
| 08.05.2020 18:24 | # 5 |
Thank you for your suggestions, I think I will get the original parts of the front team parts and the rear shock absorber. |
| 08.05.2020 18:24 | # 6 |
I used the rıw brand (206 if I am not mistaken) in my 206 cars about 2 years ago, it is hard to believe, but I changed it 1 week ago with the new one.
| 08.05.2020 18:24 | # 7 |
Rather than being original, I recommend you to use quality and known products. It is not good to escape the side industry in the products you are talking about. |
| 08.05.2020 18:24 | # 8 |
ahmed206 |
Hello, I said let me write here instead of opening a new topic. My left rear shock absorber breaks out, if I change it to may? Suggestions please.
| 08.05.2020 18:24 | # 9 |
madblueblacksea |
Sub-industry shock absorber comes 1 cm shorter than the original. I changed it but regretted it. I think it was something similar to me. Pay attention to this issue. If you are going to change the bidet one, I definitely do not recommend the other one. I think the original hard side industries will make them softer and unbalanced.
| 08.05.2020 18:24 | # 10 |
ahmed206 |
Well, did you change one or double? There is also Monroe, not as cheap as the others, but not as expensive as the original. I heard a lot of Monroe is it good?
| 08.05.2020 18:24 | # 11 |
madblueblacksea |
I changed the two. When you enter a deep pit, the stretching distance decreases and the shock absorber is soft so it hits at the last point. I would recommend Monroe a quality shock absorber
| 08.05.2020 18:24 | # 12 |
ahmed206 |
Thank you
