Parking sensor malfunction
08.05.2020 20:34 # 1
Karacocuk24
Hello friends, my parking sensor, which I put on my car 2 years ago, started to sing hard after the last 5 months, then went to the sound, only the distance indicator light was burning, when I turned back into gear, now the room is gone, so there is no sign of life, what should I do? Did I use it and also I think. The master put the seat belt mechanism behind the stop on the right side of the trunk, but it is not difficult to get the mechanism out of hand. Karacocuk24 2017-09-21 23:36:37
08.05.2020 20:34 # 2
Furkan979
If it is the same brand, you can change the box, but find out which problem is, maybe the power cord is broken or there may be water in the sensors.
08.05.2020 20:34 # 3
ggitaristt
The systems made in China are prone to deterioration .. I think that you can renew the complex .. something cheap is already very easy to connect.
For the sound problem too, the loudspeaker has a high chop and off key.
08.05.2020 20:34 # 4
OguzhanKucuk61
when it is ready, make a nice backward vision system
08.05.2020 20:34 # 5
uzunca961
I would definitely recommend looking back. If you have ready sensor holes, you will get 40 and 100e camera. Make sure the camera is great convenience
08.05.2020 20:34 # 6
Karacocuk24
You're right, let me have a camera-mountable research
08.05.2020 20:34 # 7
Karacocuk24
Today, a friend of mine went to buy from a101 because one of his sensors is broken.
08.05.2020 20:34 # 8
OguzhanKucuk61
Have solved the problem nicely :)
