Parking sensor
08.05.2020 17:17 # 1
fatih__bass
today, when I put the car in reverse, the sound indicating that the sensor has been activated has sounded differently than usual, and even though there is an object in the back, the sensor has stopped signaling, but when I put it in reverse, it always causes strange noise, can it cause rain or something?
08.05.2020 17:17 # 2
I guess you have a problem in the box where the sensors are collected from BİM: D
08.05.2020 17:17 # 3
fatih__bass
[QUOTE = ibrahim.kut] There is a problem in the box where the sensors are gathered. I guess you bought it from BIM: D [/ QUOTE]
no original vehicle will disassemble the original sensors if the vehicle is not xt premium yaw :) if it is not original:) < br>
08.05.2020 17:17 # 4
Get well soon
08.05.2020 17:17 # 5
fatih__bass
I came home this evening and tried it. I guess the rain has affected or something, I guess it does not get better.
08.05.2020 17:17 # 6
Burak
get well soon :)
08.05.2020 17:17 # 7
inceyasar
There can be water in the rain event. I had installed a parking sensor of 30 pounds before, when it shifted in the rain, it would be steady and then crashed from the back.
08.05.2020 17:17 # 8
ondercan
Look at your spare wheel, my friend. If your trunk is getting water. There's a parking sensor brain. Check it without any more damage. I think. If not, I think you'll have to change eyes.
08.05.2020 17:17 # 9
isa8yavuz
I also have the new & nbsp; 2004 model & nbsp; & nbsp; automatic gear & nbsp; 307 xt & nbsp; bought. & nbsp; parking sensor does not work in any way, so when I shift into reverse gear, no sound They said that I had an expertise in dynomoss in Bursa before I bought it. They said all electronic systems are working. What is the problem, would you help? (The original is replaced with the pioner instead of the tape changed.)
08.05.2020 17:17 # 10
Semih CAVDAR
If oxidisation may occur at the cable connections, if it has gotten dampened ... Try tightening the WD40 ... & nbsp;
