parking problem
08.05.2020 21:20 # 1
bektas5050
Hello, I recently got the 2009 model 407. When the vehicle is put into reverse, the parking assistance system gives a faulty warning, there is a front and rear sensor. The friend I bought the vehicle said that the brain needs to be changed, the original brain has been bought but there is no solution. My request is which path should I take and do you know an electronics engineer in Ankara that you would recommend to this problem?
08.05.2020 21:20 # 2
First of all, welcome to us. There are a few reasons for the problem, teacher, one of the brains was defective. First of all, the error code should be checked with an original software. then we have to check the sockets and sensors. possibly oxidation in the sockets. on the other, possibly the reverse gear sensor. If you want to have a service, you can help if you want to have a mas peugeot in Ankara.
08.05.2020 21:20 # 3
bektas5050
Thank you. Before I try myself, let me make a fault detection.
08.05.2020 21:20 # 4
emirksk
If you have an Android device, you can provide an obd connection with the torque pro program and see if there is an error code, the device named elm327 needs around 20-30TL. If you are in Izmir, we can look together.
As for the problem, I get the same error in my 207 vehicle. Either I erase the sensors or it gets better when I turn the parking assistant off and on.
08.05.2020 21:20 # 5
ocaliptus
The same is my problem. They said the brain will change, but there is no brain, and I could not find a place to repair. If you find a solution, I would be happy if you share it.
