Parking lights remain on and off
08.05.2020 19:27 # 1
xmen
As I mentioned in the title of the friends, the parking lamps remain open .. My vehicle has a headlight sensor .. everything is activated in the dark, it is not lit in the daytime ... I put the battery terminal on again, it is still lit. thanks..
08.05.2020 19:27 # 2
Alicilik
In the 307s, there is the role and insurance control panel on the battery side called BSM. There is a high probability that water will run there or there will be a short circuit. Take a look at it.
My cousin had a light bulb on his left, which was left on at first.
Then the right signal remained on. We changed the BSM brain.
08.05.2020 19:27 # 3
xmen
Thank you Ali Ali for the answer ... It is hard to be a situation like entering water, neither it rained nor the car was washed.
