Parking lamp does not work :(
08.05.2020 16:09 # 1
Friends, I bought 5 LEDs of bottomless parking lamps and had them installed in the service. I did not burn it.
08.05.2020 16:09 # 2
I Love My Pug
I probably do not understand much of the electricity, but since it does not burn, the flares break out or are connected incorrectly. but if it is wrong, the electric fault lamp is on, I know, the warning lamp or something is on?
08.05.2020 16:09 # 3
No lamps were lit.
08.05.2020 16:09 # 4
the fuse has cut the leds do not explode easily so look at the fuse, plug the old bulbs into it, if you do not work in them, the fuse has cut & nbsp;
08.05.2020 16:09 # 5
What do we do if the fuse blows, there is a relay in the car, it may have something to do with it. I do not know how to disassemble and install the electrician in order not to blow it all the time.
08.05.2020 16:09 # 6
Nothing is as easy as changing a light bulb, open the hood, try to install the original bulbs with the eyes of the day.
08.05.2020 16:09 # 7
I pull the socket is not coming, but I feel it is playing :)
08.05.2020 16:09 # 8
likely to be from insurance
08.05.2020 16:09 # 9
Muhammet CAKIR
you will pull it after you turn it.
08.05.2020 16:09 # 10
emin08
After you turn [QUOTE = Muhammet ÇAKIR], if you have a + and - pole of the led bulbs, you will hit the backside. burned ...
emin08 2011-09-27 08:51:56
08.05.2020 16:09 # 11
metin
[QUOTE = emin08] [QUOTE = Muhammet ÇAKIR] You will shoot after turning the LED bulbs if you don't have a + and - pole. not burned, burned when turned upside down ...
& nbsp;
exactly
