Park Shunt Electric Leak..
26.12.2022 17:58 # 1
illetyus
There is an electrical Leakage in my vehicle.. I replaced the battery, the battery 3 4, I couldn't know, in 5 days the starter
It's in the position that it won't turn.. I took it to a few electricians.
Nobody wanted to deal with it.. some said the tape is tendir (I tried to plug it in and the door locks) He said it was broken, I had it done, and they shook it briefly..
I tried to find out what the leak was by using two videos I saw on the internet
. I took out the old terminal and connected a lamp in between.. the lamp is almost on. I took out all the fuses inside the engine and the steering wheel, the lamp does not go out.. it only goes out when I blow the fuse no.
on the inside fuse panel.. I look at the booklet (Park shunt) .. if anyone has knowledge of what to do.. pejo 307 xt. 2003
28.12.2022 20:33 # 2
Emretekineerr
Sir, that fuse has 2 aspects, one of them cuts the electricity completely within 15 minutes. someone puts the car to sleep, if your remote etc. is working, plug it in the other side and try it after half an hour if your door is unlocked with the key
30.12.2022 08:37 # 3
antipollution
Exactly the friend said it right. I searched for leaks for days with voltmeter. It turns out that in our vehicles, the sleep mode can take 4-5 minutes, and if the negative cable accidentally touches the pole even once during the measurement, it wakes up again, gives voltage and starts again for 5 minutes. Best of all, open the hood, lock the doors, leave the vehicle for 5 minutes. Then - disconnect the terminal and wait another 5 minutes. By the way, up to 0.05 amps is normal, for example, it is used by bluetooth waiting for the key remote control, which is waiting for you to open the door automatics. I think you should get a voltmeter.
30.12.2022 09:03 # 4
Emretekineerr
It waits in sleep mode for the control of the vehicle and enters deep sleep after a maximum of 15 minutes. If it doesn't, then there is something wrong somewhere.
