Park Assistance System Faulty error
08.05.2020 21:16 # 1
maya407
Hello there,
I have the 2008 Model Peugeot 407 1.6 HDi Executive . I had left my car in a special service that looked at every brand to remove the gap in the gears. When I received the vehicle from the service, Park Assistance System Faulty started to give an error. When I called the guys and asked, "Did you crash?" (After I received the car, it was interesting that I received this error in my first contact response and were not aware of it!). I said I didn't do it either. I gave up again in the following days. They connected to the computer and said that the parking sensor had to change if it was faulty.
When I put it in reverse gear, I constantly brought this error to another service and connected it to the computer, and they said that the sensor or the brain did not fail and that the connections had to be checked.
The first service I had brought down the transmission to correct the gap in gear. Here the reverse gear is working because I get an error when I plug it back and the reverse light is on. The new parking sensor price is about 650 TL and the sensor brain is around 1700 TL. While the first service parking sensor will change, the second did not see an error when they connected the computer. The tactics did not improve by removing the cables entering the parking sensor brain.
How to tell if there are brain errors? Is there a situation where there is an error in the parking sensor and not falling into the computer? Could there be a connection problem in the cables going to the ten consoles with the brain? I would be very happy if you share information.
Thanks in advance.
maya407 2019-07-14 18:20:55
08.05.2020 21:16 # 2
maya407
The problem was solved by connecting to a computer at Peugeot's authorized service. There is no sensor or brain malfunction. Those problems were the inexperience or inexperience of the special service where I brought the car.
Thanks have a good day.
maya407 2019-07-19 09:34:27
08.05.2020 21:16 # 3
iso0625
Hello, I have a little problem with the parking sensor. Which authorized service did you have?
08.05.2020 21:16 # 4
maya407
Hello there,
Izmir Gaziemir Kahyaogullari.
08.05.2020 21:16 # 5
thanks for the feedback and information
08.05.2020 21:16 # 6
ayanilmaz
Hello there,
How was your problem resolved?
I have a 2007 model 1.6 HDI Executive 407. I left my car to the private service about 1 month ago. Shock absorbers, right front and rear wheel balls and 10,000 maintenance. Since the driver's side air conditioner flap is broken, the chest was removed from the electrician. The flaps were renewed. The clutch pedal was playing a little bit to and fro. I made him do it. Service and electrician in the same industry. When I go to pick up the car after 12 days Park Assistance System Faulty reported an error. When the electrician came to him, he said there was the same error. We took the car to the brain. He said the system was working but he couldn't transmit the sound to the speaker. The electrician removed the radio-tape again. He said nothing. I left the car and went back to work because I had a job. The electrician told me that he went to the service and had him put it on the system and that they had an electronic repair to the ground. Then in İkitelli industry, we changed and inspected the brain in the publishers. They said that there is no problem with the brain and card, there is a problem with the installation. We couldn't figure it out.
parking sensor buzze
I read that there is a piece called.
I'll be happy if you can help me.
08.05.2020 21:16 # 7
maya407
Hello there,
The authorized service operated by connecting the computer, I could not see exactly what they were doing because they did not allow me to wait on the vehicle.
Should there be a disconnection in the installation, wouldn't it be necessary to give communication errors when they connect to the computer?
I couldn't help, I'm tall. I can only recommend that you bring it to the authorized service. The worst case is that they get an appraisal fee, which I think is open to bargaining.
I hope the problem is solved in a short time.
08.05.2020 21:16 # 8
ersin61
When one of the eyes is broken, the system gives an error. It is necessary to check the wiring or the sensor eye is broken.
08.05.2020 21:16 # 9
ayanilmaz
Thank you.
I think the most logical is to take it to the service.
