Panel Play
08.05.2020 19:56 # 1
Mr.Setoo
Hello to everyone. I changed the tape of my car, after a short while the panel started to move. Any problem does not pose a problem, but when I got into the office, the screeching sound that came from the neck does not bother me, not how many times I tried to sit with my hand, I removed the separate place with the knob button and put it back in again, but nothing happened. Would it make more sense to replace it completely or would I go to the body shop or service and fix it?
08.05.2020 19:56 # 2
I think the cable that is disconnected and hanging from the back etc. Something gathered with tape rubbing against each other. Even if the tape is fully seated, even a small space can cause these sounds.
08.05.2020 19:56 # 3
samet206
The tape becomes a metal cage, this piece is fixed to the panel and then the tape is attached. I have a problem with this piece.
08.05.2020 19:56 # 4
Mr.Setoo
I was not at the beginning of the vehicle while the tape was installed, but I regret that I did not stop, all the cables were gathered and the tape was fully seated, but the teeth of the panel chest were broken.
08.05.2020 19:56 # 5
GokhaN
Get well soon there is nothing to do, even if you find it hard to change the plastic parts, it will be expensive even if you find it, don't be careful after not bothering you.
08.05.2020 19:56 # 6
Mr.Setoo
[QUOTE = GökhaN] get past, there is nothing to do anymore, if you want to change plastic parts, you find it hard, it will be expensive even if you find it don't pay attention after not bothering you [/ QUOTE]
Thank you brother. They asked for 400 lira in the service, I gave up, I think I would like to find a robust master and stick it in place.
