Painting the door handles
08.05.2020 16:55 # 1
muratozhal
Friends 206 I want to paint the frame of my car door latches in the color of the cockpit. If anyone knows the number or name of the paint, I would appreciate it if it helps. Do I need to throw varnish?
08.05.2020 16:55 # 2
muratozhal
is there anyone who can help ??
08.05.2020 16:55 # 3
simurg
When the color code of the paint opens the door of the steering wheel of the car, it writes directly to the painter, and if you ask the painter, you give it the same and you paint it, but first, you should throw a plastic paint primer under it, then you put the paint on two coats, do you have any other respects?
08.05.2020 16:55 # 4
tigerland
Does it say in the cockpit door at the door? i think org. do it or piano black is better
08.05.2020 16:55 # 5
I know if [QUOTE = tigerland] is written in the cockpit door, it says the body color there. i think org. Do it or piano black is better [/ QUOTE]
Cockpit color prints in servicebox.
08.05.2020 16:55 # 6
tigerland
I know if [QUOTE = koliva] [QUOTE = tigerland] is written in the cockpit door, it says the body color there. i think org. Do it or piano black is better [/ QUOTE]
Cockpit color will be written in the servicebox.
yes I knew it would not write at the door :)
08.05.2020 16:55 # 7
muratozhal
yes it says body color at the door
