paint repair
08.05.2020 19:46 # 1
x571
Hi
In the paint, there is a 2mm paint lift at 3 points that goes down to the sheet metal. what to do so that they don't rust? There are those who sell repair paint with paint code from gg, will it be clear over time if I buy them from these and touch them up? If you say what happens, can you show me what to do?
08.05.2020 19:46 # 2
samet206
It seems that the paint is a metallic paint. In my car, it is metallic and it is difficult to process such paints. You can do the simplest, but as follows, there are places that make auto paint, they make a paint of 50 grams with the paint code and touch it with a watercolor brush, and there is a rust appearance. obstacles, but don't expect too much. There are only those who paint on those parts of the market, but those who do this kind of workmanship may experience rare color shift. The cleanest part is in this case. I did not do it, then I just put the paste on those empty spaces, I filled them, I put on the top paint after bringing it to the surrounding paint, but there are all kinds of grins.
samet206 2016-04-30 22:32:08
08.05.2020 19:46 # 3
x571
Lousy job :( Is there anything to fix that slight rust? Where can I learn paint code?
08.05.2020 19:46 # 4
samet206
The paint code of the vehicle is written inside the driver's door or when the engine is viewed from the front, again in the part where the damper head on the driver's side is. Apart from that, as I said personally, there is no solution other than applying it to the damaged spots with a watercolor brush, because the damages are quite deep.
08.05.2020 19:46 # 5
x571
Do friends who understand from the paint code help, which is my paint code? While some of my research suggests polishing and sanding these small holes, some of them have not commented, crawl will not be like the original one, they have commented that the purpose ratio is closed. We expect friends with knowledge.
08.05.2020 19:46 # 6
ersin61
EYCC paint code
08.05.2020 19:46 # 7
x571
[QUOTE = ersin61] Your EYCC dye code [/ QUOTE]
Thank you. Do you know what the numbers on the bottom mean?
x571 2016-05-03 16:55:32
