paint and paint |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:44 | # 1 |
206x-line |
Other topic, where can I get the paint to paint the front and rear bumper trim and the door citals to the body color.
| 08.05.2020 17:44 | # 2 |
It writes the paint code on the driver's door. I know that it is enough to give the painter that code. |
| 08.05.2020 17:44 | # 3 |
206x-line |
I will do the painting after giving the code to the painter Does it fill the pressure spray can? |
| 08.05.2020 17:44 | # 4 |
206x-line |
no one had it made, so now the assembly and painting process of felt
| 08.05.2020 17:44 | # 5 |
206x-line |
Halal beg, but friends, I'm sure if someone gave this topic a little known on the site, fifty cvp would be written, but I don't understand why cvp is not given to us anyway, thanks hll arakadasa tskler read 70 times but 1 cvp al vaybe Please do not perceive this as a complaint too ... |
| 08.05.2020 17:44 | # 6 |
Let me write again :) yes, filling the spray can. The rest is nice to you, you will paint beautifully. Just give the painter a 3 digit paint code. I don't know about the felt. |
| 08.05.2020 17:44 | # 7 |
The following site is filling the spray can. All color codes are available. Haa, I don't know how good it is. http://www.724odeal.com/product.php?id_product=1305 400 ml, OEM Paint or Mix Paint Select the color code you want, fill it in aerosol cans and send it. Also if you don't know the color code;COLOR CODE OF A CAR WHERE AND HOW TO FIND THE VEHICLE? ![]() ![]() |
| 08.05.2020 17:44 | # 8 |
Nowadays, no one is standing in front of the computer from the heat, if there is no xline, come, do not rush to answer, ![]() the picture below 307 clips are the same, you will see the points you will fix when you put the felt on the hood. ![]() |
| 08.05.2020 17:44 | # 9 |
When you say [QUOTE = onurazgin] primer, you may need to throw it in the primer ..: D [/ QUOTE]
