p307 de airbag fault
08.05.2020 14:13 # 1
Ismail
As you know, we have a pegueot 307 1.6 xt premium car. When we start the car, airbag faulete text appears on the screen and crows. Also, we know that the car is locked with a remote control, but we cannot open it. -16 16:11:26
08.05.2020 14:13 # 2
Eyup Duygun
First of all, it would be more logical to connect it to the original planet2000 test device and make comments accordingly, but if the airbag failure, peugeot's family problem may have happened, there may have been other things if the curtain airbag plug was removed, etc. etc. If the control was locked on the remote control, there is a problem in the remote button, Central locking is managed by the brain called BSI, and it is useful to connect and test it again.
08.05.2020 14:13 # 3
Ismail
I got cold out of the car or I really do not know what will happen to me any more.
08.05.2020 14:13 # 4
SahinGun
When we pull the seat back and forth in our car, the airbag lamp was on, then one of the cables passing under the armpit was disconnected, I see ... probably one of the cables has no contact ...
08.05.2020 14:13 # 5
Eyup Duygun
[QUOTE = İsmail] I got cold from the car or I really did not know what happened to my cd cd clanger peugeot's chronic problem bi airbag anymore, I bought a cd clanger two days ago.
& nbsp;
If the Peugeot car has some males, these problems are accidental, or if it was played here, the situation is much worse.
08.05.2020 14:13 # 6
Sonmez
airbag faulete 206 in my car this article is also on me. It is useful to look
08.05.2020 14:13 # 7
Eyup Duygun
Go to a private service, the healthiest of which is pp2000 device. You will receive a qualified invoice + VAT.
08.05.2020 14:13 # 8
hasimayaz
It's hard to say anything without having it connected to the computer. com 2000, seat belt sensor or bsi may be missing.
08.05.2020 14:13 # 9
Ismail
The vehicle is connected to the computer. I don't think they are interested in it.
08.05.2020 14:13 # 10
HakanGokdemir
Hopefully, the problem will be solved at the thesis time.
So where are you, don't you look?
08.05.2020 14:13 # 11
iibrahimm
& Nbsp; & nbsp; I paid for a car money and it was not over yet, last month, the airbeg lamp came on, I changed com 2000, now the steering pump is out, but I love my car. "border =" 0 "alt =" Star "title =" Star "/>
08.05.2020 14:13 # 12
Eyup Duygun
friends can give different malfunctions in mixed test devices.
08.05.2020 14:13 # 13
I have had the same battery amperage may have fallen. I went down to buy cigarettes, I returned, the vehicle did not work. He said the airbag fault and started to not start, after 7-8 attempts, all electricity was cut off. Peugeot helped and then I called my master, they said the battery was dead. I changed the battery, its life was over (max 3 years). Now like a monster ...
& nbsp;
Hope this is the problem ... Easy geslin.
08.05.2020 14:13 # 14
beyaz6
hello & nbsp;
they have the same problem, they connected the car to the computer and said the signal arm was due to it and 80% repair was possible. I couldn't get it because I didn't have time. When I have it done, I write to you again on the subject.
