p1510 fault code
08.05.2020 17:49 # 1
excalibur_06
mrb.2004 307 p1510 gave an unknown error code. Does anyone know?
08.05.2020 17:49 # 2
There must be a bug with the throat butterfly. Has any action been taken recently? Open air filter etc. any vehicle? You need to clear the error and see if it comes back again.
08.05.2020 17:49 # 3
excalibur_06
last week maintenance was carried out oil and filters, change of bolts etc.
08.05.2020 17:49 # 4
So is your engine fault light on? If it does not burn, I think it is a pre-error. If I was you, I would have the car connected to the computer and I would have deleted the error. After a while, I would reconnect and see if the same error came back. If it comes back then we need to investigate what needs to be done.
08.05.2020 17:49 # 5
excalibur_06
engine fault light is not lit I erased 10 minutes later we tried again
08.05.2020 17:49 # 6
[QUOTE = excalibur_06] motor malfunction light is not lit I deleted it after 10 minutes we tried again [/ QUOTE]
So, as I said, it's a legacy error record.
