P1497 P2562 ERROR CODES
08.05.2020 19:55 # 1
gnc_ali
First of all hello everyone;
I agree with you new my car 2012 model 206+ 1.4 hdi urban move
When my vehicle is operating normally at 100 000 km the engine fault light is on
When I connect it to the computer, it gives error codes P1497 and P2562 and when it goes 20-30 km it goes out by itself
sometimes (even if the malfunction light did not come on) I could not find the reason for deafness between 2500 and 3000 rpm and it was not satisfactory in the answers given to me ... have I ever been able to help me?
The recommendations of the masters:
1. We need to wash the exhaust clogged.
2. The valve needs to replace defective
3. turbo defective needs to be replaced
4. particle liquid needs to be added
5. egr faulty
Individuals said all this and none of them speak for sure.
08.05.2020 19:55 # 2
First of all, welcome. P2562 Turbocharger Boost Ctrl Pos Sensor Circuit error I don't know the other one, but it seems there is a problem with the turbo. It does not necessarily need to be changed, maybe it can even be corrected with a simple check.
08.05.2020 19:55 # 3
GokhaN
DTC P1497 EGR Valve Problem
P2562 Turbo problem
they are talking about the car getting oxygen and not throwing it away properly after burning it. I don't think there is a big problem in the turbo.
08.05.2020 19:55 # 4
gnc_ali
There is no problem at the last speed of the vehicle, it does not appear in a turbo commander. So is there a master you can direct in Ankara?
08.05.2020 19:55 # 5
gnc_ali
Hello I am still struggling with the problem of the vehicle, I could not solve it, I did not go to Ankara, I did not go to the master, did not try, there is no advice left, my fault light is always on, I could not find a solution wesgate they say change it is the last remedy, it is left, if you get it one, it will help you to get a team with 780tl turbo, 920 TL will be thoroughly annoying. can you recommend a turbocharger
08.05.2020 19:55 # 6
If the masters can not find a solution, you will have Fatih Peugeot go fault detection and you will learn the exact source of the problem, of course, they charge 100-150 TL. I call the solenoid valve, but if it does not exceed 2500-3000 rpm,
08.05.2020 19:55 # 7
Selox
Does the electrovan sizzle? What kind of problems will it be if it is broken? Do you have any information? Do you have a picture, can you throw it? Selox 2017-02-23 17:36:32
08.05.2020 19:55 # 8
If you review the link @Selox teacher, our friends who explained the process.
track photo
sonerkyl 2017-02-23 17:41:06
08.05.2020 19:55 # 9
Selox
Eywa. brother brothers respect :) We learned.
08.05.2020 19:55 # 10
you're welcome @Selox
08.05.2020 19:55 # 11
gnc_ali
hello I could not solve the problem of my car, the same problem was going on, p1497 error code deletion was not giving any more error code but it was giving the p2562 error code did not improve.
08.05.2020 19:55 # 12
[QUOTE = gnc_ali] hello I couldn't solve the problem of my vehicle, the same problem was going on, p1497 error code deletion was not giving any more error code but it was not giving error code p2562 did not recovered. QUOTE]
Hello, my teacher, I hope you can find a vehicle according to your heart.
