P1352 - Engine Fault Code
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 21:24 # 1
BarbarosTUGRUL
Hello friends,
2012 Model 1.6 e-hdi Active model car owner, When I start my car, the engine malfunction warns me to have the car repaired. When I recite it from Ecu, I get the error "P1352 - Engine". Although there is no clear information on the internet, I have come to the comments that it may be in glow plugs. Why do you think this malfunction code comes
Good luck with
09.10.2023 09:59 # 2
BarbarosTUGRUL
I solved the problem myself. For those who may need it in the future; Hello, I own a 2012 1.6 508. I have been using it for a long time and am happy with it. Recently, I have been getting the P1352 - Engine error message on my car. When I took it to the mechanic, he said that the tension belt - battery - battery tray needed to be replaced in this order. I couldn't have it done due to financial constraints at the time. However, the problem started after the thermostat replacement. The other day, when I went to replace the water pump and thermostat because the temperature in my car was higher than it should, I noticed that 1 ground cable was not connected. I asked the mechanic to replace the cable and the error was cleared. The fact that I got the error because of only one cable not connected is another situation that most mechanic are unaware of this problem. If you encounter this error, have them check that the ground cable, which should be somewhere on the thermostat between the injectors, is connected. Finally, a relative of mine had the heating relay disconnected. Good luck...
10.10.2023 14:07 # 3
Thank you for the information, sir. Unfortunately, such problems can occur due to mistakes made by the master and apprentice.
