P1351? |
| 08.05.2020 19:54 | # 1 |
First of all, when I searched the forum, I understood the meaning of the error code P1351 and what I should do. However, before the engine starts, when I turn on the ignition, the indicator also turns on the yellow engine light. I'm waiting for it to go out, it doesn't go out. Yellow engine light goes out 3-5 seconds after starting the vehicle. There is no problem in traction, on departure, on work or turbo, as far as I have observed. It is the first time I use a diesel and pevgeot brand vehicle and I am a stranger to the engine. In the morning when I searched for an error code with my ELM327 device, I got the error P1351.
I think the engine light is on because of this error. Or it may have nothing to do with this error. I would like to thank those who can provide information on this subject in advance. Best regards. |
| 08.05.2020 19:54 | # 2 |
sonerkyl |
the engine light does not go out before the vehicle starts, 3-5 seconds after my teacher starts. As you said, it turns off, any problem comes to the error code about it P1351 IDM input circuit fault / ignition coil control circuit High voltage SID 803 / EDC16C3 - Pre / Post relay circuit heating. Relay and uncontrolled glow plugs are supplied. |
| 08.05.2020 19:54 | # 3 |
Thank you for your interest and interest "sonerkyl". I guess it won't be a problem in the long run, but as far as I can tell you, I have to have the spark plug and ignition coil control circuit checked. Hopefully I will find a master who is a master of this job in the city where I live. Thank you again. Best regards.
| 08.05.2020 19:54 | # 4 |
sonerkyl |
You are welcome, your teacher from the glow plugs (heating).
| 08.05.2020 19:54 | # 5 |
I will start to circulate the industry soon. I'll have the glow plugs checked. I don't know how much anymore, but it is necessary. Thank you again. Best regards.
| 08.05.2020 19:54 | # 6 |
sonerkyl |
My teacher, who is 25-35 TL or more, keeps some workmanship.
| 08.05.2020 19:54 | # 7 |
Well, if I can find a master to do it in Kastamonu, 35 - 40 TL Labor is not a problem. Thank you. Best regards.
| 08.05.2020 19:54 | # 8 |
sonerkyl |
4 of them are already available. http://www.peugeotmarket.com/peugeot-307-16-hdı-ısıtma-bujısı-orjınal,pr-1318.html
| 08.05.2020 19:54 | # 9 |
Hello again. I came from the master now, whatever you like the guy said: "Well, this is an easy job that your brothers call this engine a very complicated suction spark plug. Take four try and come and solve the problem!" said. I said that I am satisfied and I left. Now I install the gasoline engine, including the electronic parts. I'm afraid of diesel, but I will take it from the particle and replace it myself. Of course I struggle a bit, but I think I can do it as a result. Hepi ball spark plug after all? Best regards.
| 08.05.2020 19:54 | # 10 |
Mr. Sonerkyl; I can't address you because I don't know your name, please apologize. I am Levent. My car is exactly 2005 model 307 1.6 HDi LOOK 110 BG. I want to have my vehicle stabilized. I also found useful information in my research in the forum. However, I still wanted to confirm whether the accelerator and brake pedals are electronic by removing the steering wheel of my vehicle. I think my brake can communicate with a 4 wire socket. As far as I understand, my accelerator pedal has no wiring. Still, I take pictures and share them. Ricam Could you please give me information as to whether speed stabilization will appear as it appears in the pictures? Thank you Best regards. PICTURE 1: http://hizliresim.com/o7Wb1R PICTURE 2: http://hizliresim.com/ZdB80o
| 08.05.2020 19:54 | # 11 |
sonerkyl |
No problem, Levent brother, if you buy the original arm in my name, it will cost you around 250 TL. If you buy arm made in China, it has a price of 60-70. 40-50 tl or something. Unfortunately, in small provinces, unfortunately, the problem of the master is that the glow plugs are a bit of a tough teacher.
| 08.05.2020 19:54 | # 12 |
Nice to meet you, Soner brother. Thank you for your interest. The cruise control work, which will be costly, I hope to the next month. As you said, finding a master is a problem here. I'll put the spark plugs on another master tomorrow, let's see if he can? Thank you, I wish you good night. Best regards
| 08.05.2020 19:54 | # 13 |
sonerkyl |
I request it, my brother, Levent, hopefully he will have a problem.
