P1340 Flicker Malfunction Emergency Assistance
22.11.2021 16:08 # 1
berkant12
Hello, I have a vibration problem that has been going on for about 2 months in my car. No one can detect the problem, everyone says afakki top cover will open.
COIL & BUJI & 1920.LS CAMSHAFT SENSOR & THE ELECTROVATE SENSOR HAS BEEN CHANGED.
However, We put the sensors I mentioned below to come off, the vibration problem in the car and the p1340 warning goes away instead of the sensor failure. I think the sensors are incompatible, that's why we said that the malfunction lamp is on. ORIGINAL ZERO I bought 3 sensors that I specified. The absence of vibration from the detached part, the shaking of the car in the zero part, I am waiting for your help for the abnormal solution ( ANKARA )
1920.LS ( CAMSHAFT SENSOR 2 PCS < /div>
1628924280 ELECTROVALVE SENSOR 1 PCS (on the front)
24.11.2021 10:37 # 2
Hello.
Is the car engine 1.6 vti bro. If it is 1.6 vti, I recommend you to go to SF Garage Serdal Usta in Ankara.
26.11.2021 16:37 # 3
berkant12
Yes sir 1.6 vti have you ever experienced such a problem?
I'll definitely stop by tomorrow
27.11.2021 19:49 # 4
antipollution
Have engine mounts been checked after ignition
29.11.2021 15:04 # 5
berkant12
There is an engine failure, sir, p1340
