P11AA error code
30.11.2022 01:32 # 1
derdest01
Hello, I am getting the code P11AA and the fan is running constantly, when I delete this code, the fan stops. Does anyone know what the error is?
06.06.2023 17:12 # 2
uiyigun
Hello, have you checked the engine cover of your vehicle, if there is air leaking from somewhere, you can check that as well.
07.06.2023 16:44 # 3
derdest01
[QUOTE=uiyigun]Hello, did you check the engine cover of your vehicle, etc., if it is taking air from somewhere, you can check it.[/QUOTE] Thank you for your interest, sir. It was giving such an error because it was taking air from the upper rocker armature horn, just as you said, the problem is solved.
