P1023 VARIABLE VALVE SLIDING SYSTEM ERROR
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 20:20 # 1
mustafamertcan
Hello.I am 44 years old from Mustafa Kocaeli.
508 I bought it with pleasure. The last time I took it to a different mechanic;
p 1023 fault said that it can reduce the value from 9.9 to 3.4 but the value should be 1.7. Knowledge about the subject, the master he can recommend etc. I would like your support. The only hope is to reach the right information from the Form. Respects;
08.05.2020 20:20 # 2
First of all, welcome to our brother Mustafa. I think if the car started with gasoline problems after the replacement of the cylinder head gasket, the fault of the collecting master seems to be the cause, because it is a problem that they cannot possibly adjust the sentence because my advice is to go to a good peugeot master in my region, etc. Do not believe it, it would be best to go to other masters or to a good authorized service and make a fault detection (they want a number like 100-150 TL) and act accordingly. Our forum members will advise on master. But as I said, my brother has the best fault detection done in a good authorized service.
08.05.2020 20:20 # 3
citroen mehmet
Brother Mustafa get back again. Did you know the problem of the 508 vehicle.What is the problem, I try to help you brother
mobile: 0535 362 50 62
21.12.2025 15:56 # 4
community
How can I contact you?
