P0606 malfunction and a lot of other malfunctions
08.05.2020 20:08 # 1
ergr
Hello friends,
My 2008 dynamic package 1.4 car has the following problems and I cannot get out of it. I am waiting for your urgent help.
-The vehicle was 142,000 original km but I got the damage recorded, I had all the checks done, there was no problem but when I started the car 2 days later, the fault light came on and when I connected it to the computer, it started to give p0606 errors with p0183. The vehicle does not exceed 3 thousand revolutions and it protects itself continuously. When I turn off the ignition and start it again, the malfunction goes away. but this error continues all the time and I always have to run the tool again.
-When the temperature reaches around 70-80, the vehicle seems to cough if it is idling.
-3 days ago, when the vehicle was stopped, the self-wipers started to work and the headlights turned on, it did not improve despite removing and inserting the battery twice, then it went to itself if it happened, I am afraid of doing it again,
-I had gone through a pit with the car and started to give airbag failure according to his head and it was annoying,
-When I turned on the rain sensor today, it started to operate the wipers at the top speed even though it was not raining very much, it was not doing anything like this today.
please I am waiting for your urgent solution suggestions.
BEST REGARDS
08.05.2020 20:08 # 2
firstly welcome. error codes
P0183 FUEL HEAT SENSOR A CIRCUIT HIGH INPUT
P0606 PCM PROCESSOR ERROR (vehicle has ecu problem, teacher or contact due to contactlessness and oxidation in sockets) idling, etc. This results in fluctuation and low traction of the vehicle.
when it comes to other problems, the car retrofitted sound system - xenon bulb etc. If it does not exist, it may cause this type of problems because the wiring is not collected while the vehicle is being collected. it's probably a short circuit somewhere
08.05.2020 20:08 # 3
ggitaristt
Soner is right. You need to find a super peugeot electrician.
