P0011 P11A9
29.03.2023 10:31 # 1
Mertt207.5
Hello friends,
In my Peugeot 207 - 2009 - 1.4 VTİ petrol vehicle
exhaust emission failure-raw fuel-engine fault lamp is on
When we connect it to the device, p0011 - p11a9 ie;
Input camshaft phase decay
Input camshaft position actuator solenoid valve
It gives its faults. The electrovalves on the front and rear of the engine have been changed
But it is still not resolved, I would appreciate it if anyone could help me
We can't find a master C onfused
29.03.2023 11:31 # 2
MehMetC3
Does the vehicle have LPG?
29.03.2023 12:55 # 3
Mertt207.5
yes there is sir
29.03.2023 12:56 # 4
Mertt207.5
yes there is
30.03.2023 23:43 # 5
MehMetC3
An engine that doesn't like LPG is VTİ, I think it burns raw fuel. Situations such as smoke throwing usually happen when there is a malfunction in the valve structure. Since LPG has a high heat value, there are deteriorations on the piston front of the valves and this results in such results. but a good master will know better than us.
03.04.2023 17:55 # 6
Mertt207.5
FRIENDS, THE PROBLEM IS SOLVED, YOU HAVE NOT FIXED 2 OF THE ECCENTRIC HOLDERS
WE ATTENTION TO THE MASTERS YOU HAVE OPENED THE VALVE OPEN
