p 1327 fault code
08.05.2020 14:52 # 1
elcinaydogdu
Friends 2004 307 lpg lighted motor malfunction light comes on frequently. When connected to the computer, p1327 malfunction record is detected in the form of integrated phase due to not turning on the lights. We could not find the solution in the full sense ... why does the vehicle cause this malfunction and what can be the actual explanation of this code?
08.05.2020 14:52 # 2
H-a-d-i
Your first message 1 year after registration! congratulations ... and welcome.
08.05.2020 14:52 # 3
ispinoze
Hello,
The same problem existed in my vehicle. My vehicle is 2005 model. It originates from 90% LPG. Usually it is made from poor mix. I went to the place that wore my lpg and got it set to the master. He deleted the error code and did not make the same error again. It's been about a month or so. Also try not to exceed 3000 3500 cycles. This error occurs at high speeds.
08.05.2020 14:52 # 4
I do not think that it will have anything to do with whether the 3000-3500 period passes, but I do not claim it. Of course, if there are troubles in the past of 3500 times, there is of course a mistake. Otherwise, the car will not be used as well. the engine forgets to see the red line, then mazallah Gülme
the cecol 2010-08-25 14:27:29
08.05.2020 14:52 # 5
rifatseker
I looked a bit on the internet, this error is explained as follows according to the error codes of peugeot;
check ignition primary pattern for excessive peak voltage and spark line too short. Should be greater than 1ms. This fault code is usually caused by interference.
* Check the primary ignition system peak voltage and spark need to be short, 1 ms higher, usually caused by interference (electrical), has a description. You can connect it to the computer and have it set on the ignition settings. You may need to look separately for gasoline and LPG brains. You can also have a look at the Poor / Rich mix settings.
* It is useful to have the ignition coil and other ignition related parts checked.
rifatsek is 2010-08-25 15:49:49
08.05.2020 14:52 # 6
ispinoze
[QUOTE = cecol of]
Walla brother, I can not see that yellow light, whether it is red or not to show me :) I had to hurry somewhere I forced the car in 4000-5000 revolutions. I parked the car. I came half an hour later, this mistake. Then I worked for 15 days until I left
08.05.2020 14:52 # 7
air fuel sensor malfunction
08.05.2020 14:52 # 8
alpbeyazi
[QUOTE = Come on] your first message 1 year after registration! congratulations ... and welcome. [/ QUOTE]
Alkış
08.05.2020 14:52 # 9
elcinaydogdu
Thank you guys for your answers. We also liked it ..... I went to the autogas station that assembled lpg to my vehicle in Ankara today and I explained the situation. First of all, they started the word with classical words. They advised that it was necessary. Then they connected the vehicle to the computer and adjusted the gas settings again.They said that the gas setting was low and they raised a little. come and be satisfied ....
08.05.2020 14:52 # 10
[QUOTE = elcinaydogdu] friends thank you for your answers.we also welcome ..... today i went to drop autogas which is assembling lpg to my vehicle in ankara. They advised that I should not see it by saying that it would not be a problem. Then they connected the vehicle to the computer and adjusted the gas settings again.They said that the gas setting was low and they raised a little. come and be satisfied .... [/ QUOTE]
once that lamp is lit, the air fuel detection sensor is malfunctioning, some vehicles do not have a problem, but I hope I heard that some vehicles cause problems up to 3000 TL. Sleepy
08.05.2020 14:52 # 11
kayaca
Is there anyone who can help with this?
02.04.2021 16:55 # 12
Simuzer
I haven't connected the tool to the computer for a long time. I connected it today and there was this malfunction in the fault records.
In congested traffic, when I slow down suddenly and stop at red lights, the vehicle stops. I think there is a problem with air-fuel intake at idle There is no problem in normal course.
My vehicle has no LPG. 2003 model C3, 1.4i BVA
05.04.2021 09:22 # 13
It may be if it is getting air from somewhere or if the throttle valve is very dirty. It may also be sourced from the fuel system. When was the last time the fuel filter changed.
