Oxygen sensor malfunction
08.05.2020 20:49 # 1
Oguzhan1818
Friends, the malfunction lamp was on my car, we connected it to the computer and looked at the error
Error1 P0135 O2 sensor heater circuit row1 sensor1
Error2 O2 sensor circuit row1 sensor1
The oxygen sensor is inserted and cleaned and the tactic continues, could it be caused by somewhere else or the sensors are finished?
Thank you in advance I'm waiting for your CVs
08.05.2020 20:49 # 2
Unfortunately my brother will have to buy a new one of the oxygen sensor. It was around zero 200 TL.
08.05.2020 20:49 # 3
Oguzhan1818
Will the potion be changed or is the bottom set on the top?
08.05.2020 20:49 # 4
both of them seem to be faulty.
08.05.2020 20:49 # 5
Oguzhan1818
Thank you bro
08.05.2020 20:49 # 6
ayoz
Hello, I have been dealing with the same problem for 1 year. My problem
My vehicle 1.6 16v 206 110 ps SW 165 thousand tubes are not installed in my vehicle
ANTİPOULD FAULD error When we connect OBD, P0141 O2 sensor gives heater circuit error.
The brain has changed
2 sides of the sensors changed
catalyst cover was opened and checked
all filters changed
spark plugs changed
CAR LIFE IS SEVEN but it has not improved.
25, 30 days no error comes, no matter which electronicsman tampers with the car.
diddddd sound and damn text come out and light the engine fault light
08.05.2020 20:49 # 7
Boyunique
Brother have you tried the map sensor? I also got an antipolito foil error du I wanted a map sensor from China I wanted it to be fixed, even after I started it, the malfunction light turned off
08.05.2020 20:49 # 8
Oguzhan1818
I haven't tried, brother, where did you order?
08.05.2020 20:49 # 9
Boyunique
I said from Ali ekispres, only comes 15-20 days later
08.05.2020 20:49 # 10
Oguzhan1818
Brother, can you send a link to you?
08.05.2020 20:49 # 11
Oguzhan1818
Can we talk to my brother privately 5536522922
08.05.2020 20:49 # 12
Devran
hi friends .. i have peugeot 207 1.4 hdi car .. antipollution faulty malfunction and map sensor malfunction.
Also, while the car is running at idle sometimes, it runs irregularly for a short time, then it gets better .. I renewed the map sensor, but I am still having the same problem .. now I am replacing the oxygen sensor .. but I did not find where to burn the sensor .. !! I would appreciate it if anyone knows its place and helps .. thanks ...
08.05.2020 20:49 # 13
Devran
Is there a friend who knows ..?
08.05.2020 20:49 # 14
crazysado
the oxygen sensor is on the manifold cable is usually white color. I bought the brand of bosh cable color blue it can be boiled with a little troublesome to disassemble it.
07.12.2020 02:08 # 15
Yabanci26
Friends, this peugeot 306 platinium 2001 model vehicle, can we change the oxygen sensor by ourselves and where is it? Can you take a picture? It is said that there are 2, where it is, I guessed it gave me a fault code. Can you show both of them with pictures, the vehicle started to burn too much and it started to stall in the first works. Sometimes it does not go on the road, sometimes it comes on later, but as if there is a drowning, the vehicle is constantly faulty, the lamp is on again, it burns out again, it burns again with a flasor. I was writing something related to me. I will go back to the industry again today. Can you give me a CVP from private or e-mail? Thank you emin.etes.es@gmail.com
07.12.2020 20:03 # 16
Berkay Erdinc
[QUOTE = ayöz] Hello I have been dealing with the same problem for 1 year. My problem is My vehicle 1.6 16v 206 110 ps SW 165 thousand has no tube installed ANTIPOULD FAULD error When we connect OBD P0141 O2 sensor heater circuit error. Brain changeover sensors 2 side changed catalyst cover opened and checked all filters changed , 30 days no error comes out, then the diddddd sound and damn writing comes out and the engine turns on the fault light [/ QUOTE] The oxygen (lambda) sensor is located on or near the manifold. Its task is to measure the exhaust temperature and send it to the ecu. ECU adjusts the air-fuel mixture according to this temperature. When the ecu exhaust becomes too hot, it increases the air intake and decreases the exhaust temperature or vice versa. This sensor decides whether the car will work with a rich mixture or a lean mixture. They call it Afr setting. You do not have any trouble so far, the ecu has changed in the sensors. But there is a map sensor in the meantime. To put it briefly and simply, how much In summary, your oxygen sensors have sent a signal to the ecu. You have to make a poor or rich setting. Ecuda cannot receive data from the map, so your oxygen sensors may be warning that there is something wrong because your afr setting cannot be adjusted. The option also affects the afr setting in everything related to ignition. Spark plug, coil, injectors, etc. Maybe the oxygen sensor you disassemble and replace and the ecu may be in good condition. All of the oxygen sensor has failed but the part that gives him the warning that gives him the error is what is the problem. I hope you will solve your problem in a short time.
07.12.2020 23:41 # 17
Yabanci26
Thank you, my master, today we put it in the computer, it has failed, but the malfunction lamp has not been lit for a week, today we have looked at the computer malfunctions. The master wearing the bobbin was shaking and standing, he did not connect it today, we fixed it with a screw, they said that he can do it now, we will break down for 1 month and we will try again, if the car burns again, we will change it. There are many masters who do not know very important, we will try and see these topics. Thank you.
