OXYGEN SENSOR FAILURE ..
08.05.2020 18:40 # 1
toprak83
Have you ever had an oxygen sensor malfunction in my car, have you ever had this kind of trouble? The only remedy is to replace parts or are there other solutions .. ?? 2006 model 206 xdesign ...
08.05.2020 18:40 # 2
Ali1905
I have an exiting oxygen sensor.
08.05.2020 18:40 # 3
toprak83
lower or higher? what is the price ??
08.05.2020 18:40 # 4
outlaw
I HAVE O OXYGEN SENSOR ERROR ...
VEHICLE FUEL IS EXTREMELY LIKE ...
CLEANING WITH THE LAUNDRY WATER FIRST, AND SOMETHING IS PROBLEMED, BUT IT IS CHANGING IF IT DOES NOT ...
08.05.2020 18:40 # 5
ahmed206
What other problems do the oxygen sensor have when it fails?
08.05.2020 18:40 # 6
outlaw
THERE ARE NO PROBLEMS IN FUEL OR WHEN THE ROLEANT PROBLEMS ARE NOT INFLATABLE ...
BUT THERE ARE THE MOST WRAPPED CAR AS I AM NOW ...
08.05.2020 18:40 # 7
Ali1905
teacher, I threw pm
08.05.2020 18:40 # 8
toprak83
[QUOTE = ahmed206] What other problems arise when the oxygen sensor fails? [/ QUOTE]
The vehicle stops, shifts when shifting ... makes tremors ... there is no problem with fuel burning, I just stopio vehicle ...
08.05.2020 18:40 # 9
06fatih66
the fuel of the vehicle increases and most importantly the catalyst malfunctions, so change the sensor without using the vehicle for too long. Without a sensor, it cannot measure ecu values.
08.05.2020 18:40 # 10
toprak83
my hesitation is that after replacing these parts, the same troubles still continue ... after the expense does not improve after the problem ..
08.05.2020 18:40 # 11
semih.danak
vallla has the same problem in me, they say that the fuel burns too much, if they have a different lpg in the car, they say that it will not work, I think they can not measure the lpg.
08.05.2020 18:40 # 12
toprak83
I asked the master, the new tactics sensed, does not break, the die gets used to me, he replied to the LPG, he did not satisfy me very much ... my vehicle's troubling was low and the pressure on the clutch would not stop from time to time. very well ... my only tightness is that it shuts down when changing gear ...
08.05.2020 18:40 # 13
kerten
rich or poor mixtures can disrupt the oxygen sensor, when replacing the oxygen sensor, you should also eliminate other factors that cause a rich or poor mixture. For example, faulty software, bad injectors, bad fuel ... these always disrupt the oxygen sensor, you replace the oxygen sensor, but the new one will be broken after a few months, taboo in the meantime, the catalyst is blocked and you start to damage your vehicle. If you can get a familiar one, read and record the values before replacing the oxygen sensor with the wideband and before replacing it, you will reach the result more quickly.
08.05.2020 18:40 # 14
ahmed206
[QUOTE] very good on long road, very good on fuel ... my only tightness is stopping while shifting gears ... [/ QUOTE]
get used to ???
If this wasn't how it got used to at first, it wouldn't happen later.
masters think that he always deceives us.
